Dump valve problem
Old May 23, 2005 | 11:20 PM
Dave_RST's Avatar
Dave_RST
Default Dump valve problem
I've fitted a piston type dump valve to my EFi managed escort turbo and the only problem seems to be that it hisses all the time until it comes onto boost I can't say I've ever noticed this before when I've been in other turbo'ed cars.
Anybody got any idea whats up?
Cheers,
Dave.
Old May 24, 2005 | 08:21 AM
james_birch's Avatar
james_birch
you running efi and you want a dump valve?!
WHY? chatter so goooooooood!
Old May 24, 2005 | 09:06 AM
220TC's Avatar
220TC
you need a stronger spring in there mate, give forge motorsport a ring, they have about 5 different strength springs depending on your boost level.
Old May 24, 2005 | 09:27 AM
Oranoco's Avatar
Oranoco
Or just file the dv in a drawer in your garage.
Old May 26, 2005 | 09:48 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Or file it on Ebay!!
Old May 26, 2005 | 10:44 AM
sufsRS's Avatar
sufsRS
wish i had EFi! chatter all the way chuck the dump valve out the window
Old May 26, 2005 | 10:48 AM
FordFans's Avatar
FordFans
I'd prefer chatter over the DV anyday, but if you insist on the DV it does sound like a weak spring as already mentioned
Old May 26, 2005 | 01:17 PM
adamS2RST's Avatar
adamS2RST
Or a boost leak in general, either way file the chump valve in the bin
Old May 26, 2005 | 07:41 PM
Dave_RST's Avatar
Dave_RST
Ok then I'm a bit new to turbo cars, whats chatter??
And why does EFi make a difference?
Old May 26, 2005 | 08:47 PM
DanRSturbo's Avatar
DanRSturbo
Chatter is the noise made when the wastgate open's and closes, Fiesta Turbo's chatter well because they have no metering unit, as do Cossie's. I used to run a dump valve on my RSt, but it chirps a little now so I flogged it on e-bay. Depends on your taste really m8.
15
Oct 7, 2015 03:43 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
