Bailey Dump valve
Ive just fitted a Bailey DV24 dump valve to my 3door. I have noticed that it can injest foreign material into the trottle body when its open at idle. IT also has a rather annoying whoosh. Does anyone know of any way of filtering the air going in and making the whoosh quieter? icon_wink.gif
Surely the valve opens under manifold vacuum, which is present at idle. If you adjust so it doesnt open under idle vacuum (20Hg approx) then it surely wont open any other time??? My understanding was the valve closes when you start making positive pressure........does anyone else have any views on this?
i've got a DV24 on mine and is meant to have the piston open on idle... then shuts when you accelerate. with the car idling open the throttle butterfly slightly to rev the engine and you'll see the piston come back down.
therefore it is possible for debris to go in... only real alternative is to get a group-A type valve which has a filter built into it, and they tend to be a bit quieter too!!
I have a DV24 and am also slightly apprehensive about idleing on a dusty road and basically sucking dusty shit into the throttle body.
Makes me wonder what my Air Filter is for
if you're bothered about your dv being open on idle
buy a Blow Off Valve, such as a GReddy or a HKS
BOV's stay closed on idle, so dont suck in any nasty bits
ive got a GReddy type S on my saph, works a treat.
