best valve springs?
Is it possible to use standard ford valve springs with a 285t2 cam.
is anybody doing this with good results?
if not what are the best anti coil springs, not happy with my piper springs.
Thanks.
Thanks.
Originally Posted by Christian and Beccy
Out of interest, why aren't you happy with your Piper Springs??
A couple of replies i had about a recent post of mine suggested valve float or possibly a worn cam but the engine is only 3k old, i run the cam in properly. I did notice that my original valve springs were a little tougher than my new piper springs, obviousley due to less material
Basicaly my car is loosing power between 5 and 6 thou.
Is it Misfiring?
It could be lifters. Thats quite likely.
the best cvh springs to buy see david baker at www.pumaracing.co.uk thats what i am using they are his own system he has made due to the problems with the cvh valve springs going coil bound u wont get any valve bounce with the turbo rev range tested to 8000rpm...... for cams see newman cams excellent quality and will out last kent and piper cams, piper quality are not too bad but kent
i'll never buy one again
Is it Misfiring?
Its the way it looses power, just seems to stop pulling at about 5 thou, doesnt sound right after that.
Im using a turbo technics stage 3 blower and the engine runs sweet, no misfire allways runs on optimax. Everything is new and set up right. The lifters are pipers own, 3k old.
Originally Posted by swerv
many years ago we used a piper T2 cam with standard springs and it wore out in 500 miles and knackered everything
so i would so do not use standard springs.
i'll never buy one againWhere can i get a newman cam from?
cheers
go direct to newman for there cams www.newman-cams.com i had one of there off the shelf cvh turbo cams but then i wanted one more radical then the cvh37 so they done me a custom cam these are the only cams that will last in a cvh engine email david at pumaracing i have just spoke to him no problem doing you a set but he has so much work on.. kent and piper springs are shite they just dont work right
ask him whose double valve springs they are because i thought that newman dont do any i could send you some photos of my setup if you pm me with an email address
Just been out in my car again and it is really anoying how it gets to 5 thou and looses momentum, even sounds different through the zorst.
How come on this months performance ford the piper kit they use comes with double valve springs? recent upgrade by piper?
david at pumaracing fitted his double valve springs when he done me one of his 45mm inlet valve head ported cvh heads
do you use solid lifters? is there any point me purchasing them if im only planning on revving to 6200.
Do you think the newman off the shelf turbo cam will be enough. i.e is it a mild or wild one, on comparison to 285t2.
newman cams only work with solid lifters because they are chill cast blank Hydraulic lifters would knock the cam lobes out quite quick i dont know the profile but ava use the cams in all there cvh heads one of them shows peak power at 6400rpm the cylinder head is excellent gives 50bhp over any stage three head u care to use
thats the combination im gonna try, just need to know where to buy a newman cam from.
how did you raise your rev limit?
He said the rev limit would now be governed by the chip,and that turbosystems who chipped my car set it at 7050 rpm,and it does rev to 7 000 now lol.
Nope , anti pumps and double valve springs. going to change to newman cam and maybe solids. running a piper t2 at the mo.
SMILER258
Sep 28, 2015 09:04 AM
