Sub Boxes..
Old May 3, 2005 | 06:29 PM
BillyCabrio's Avatar
BillyCabrio
Default Sub Boxes..
Any tips?
Popped into Halfrauds today just to browse the selection and the fella started going on about different sizes (as in cubic feet) for different subs??
Any advice? I'm after a twin 12" holed box, now should it be ported or not? What size should it be??
Oh and wheres a good on-line place to buy this kinda stuff?
Old May 3, 2005 | 06:30 PM
BillyCabrio
I've been looking at this....
http://cgi.ebay.co.uk/ws/eBayISAPI.d...770428187&rd=1
Old May 3, 2005 | 06:34 PM
Paddy's Avatar
Paddy
Legend
depends what kinda bass you want whether it should be ported or not and the manufacturuer of the sub will recommend a cu/ft for the optimum sound.
altho with 2 x 12 inch subs, you should DEFINITELY get a ported box and probably some neons and some friends that hang outside mcdonalds a lot
I find my 10 incher performs perfectly in a sealed box.
Never had any complaints.
Old May 3, 2005 | 06:39 PM
Stu.H's Avatar
Stu.H
A ported box gives you a lower bass frequency, eg for music like snoop/dre, not so good for dancy tunes.
A sealed box would be better for dancy punchy bass.
Yes, ever make of speaker needs different sized boxes.
Also bear in mind, a ported box needs to be roughly half the size again of that of a sealed box. The port itself, in the length it goes into box and the hole size is very important, it can drastically change the way the bass sounds.
A good recommendation for a bass sub/amp combo is the JL Audio 1000/1 monoblock amp and a 15w3 (or 15w7 cant remem) sub, again by JL audio.
just get some reinforcements for the windows and a split charge battery system
Old May 3, 2005 | 07:01 PM
BillyCabrio
I already have the goods.......... 2x Pioneer 500w 12" subs.
Excuse the wanky box there in, soon to be replaced......
So what now?
Old May 3, 2005 | 07:13 PM
Stu.H's Avatar
Stu.H
get on pioneers website and check out the dimensions needed!
Old May 3, 2005 | 07:23 PM
ronf42's Avatar
ronf42
http://diyaudiocorner.tripod.com/software.htm
some speaker box design programes , not looked at them yet though
Old May 3, 2005 | 11:27 PM
BillyCabrio
I spose i better try and find out the model number too then!!
Old May 4, 2005 | 07:20 AM
Paddy's Avatar
Paddy
Legend
Should be on the back of the magnet
They look like the TS series to me
Old May 4, 2005 | 07:45 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I am under the impression that a ported box will sound louder at a given frequency (tuned by the port's size, shape and length), tailing off either side, whereas a sealed box will have a more consistent level across the frequency range. I am delusional ?
You might be better off (sound wise, not necessarily financially) buying a box with subs that have been designed to work as a pair and flogging your two subs.
You could also ask on the following boards:
http://www.caraudioforum.com/vbb3/index.php
http://www.talkaudio.co.uk/
http://www.carstereo.com/forum/index.cfm
I don't go on any of them, just found them in google so can't comment on how good/bad they are.
Godd luck.
Old May 4, 2005 | 08:57 AM
Martyn's Avatar
Martyn
That depends on what sort of dance music is it!
I listen to hardcore/oldskool and dnb, which is mainly all about the bass and has loads of low frequencies.
Ive got a 10" ported Vibe box which does the job perfectly
Old May 4, 2005 | 09:08 AM
Jim Galbally's Avatar
Jim Galbally
billy, this box any good to you?
its ported, and i think they're 12s
Old May 4, 2005 | 11:31 AM
bassboy's Avatar
bassboy
Hi Billy, if u want a custom box made i can make you one no problems...
about the size of the box...about 1.25cuft per sub sealed would be perfect for the subs..
depending on how you like your music and what music you listen to, will determine what sort of box you should go for...
i myself have a pair of Pioneer 12's in one of my own boxes which is about 5.65cuft after port displacement and speaker displacement etc etc and FOOK me does it drop! the box is HUGE simply becuase i like the LOW frequencies...certainly has made a number of ladies smile LOL
if you listen to fast bass, like dance etc, then stick with sealed, if you like rap, hip hop etc then ported...
you might even find 1 12 in a ported box is more than loud enough for your needs if you wanna chat in more detail, add me on messenger on bassboy_loud@hotmail.com
bassboy
Old May 4, 2005 | 11:35 AM
RichardPON's Avatar
RichardPON
I much prefer sealed boxes.
My old 12s used to drop no problem - loud as fook too, when bridged across the old Genesis Monoblock
Old May 4, 2005 | 11:42 AM
jasonp's Avatar
jasonp
i use to make boxes for Ł10 and people just screwed em together. Use to make about 20 a week, and acoustic shelves. Maybe i should make some again and could bung a few on ebay
Old May 4, 2005 | 11:45 AM
Mike C's Avatar
Mike C
The Special One
I just bought one of them off E-Bay, shud be arriving any day now
Old May 4, 2005 | 04:23 PM
Eagle's Avatar
Eagle
Super Moderator
its always better to diy than buy a ready built one ..
i got a cheapy pair of 12's but built the box according to the theile characteristics and bloody eck did they drop well .. even put my mates very expensive ones to shame..
BUT the box was huge only just fitted in the back of the erst about 2 inches below the parcel shelf and 3 inches either side ..
plastic drain pipe makes a good porting material but dont forget to make the box nice and solid with supports for the port .. the ends can be melted into a curved shape this allows a better sound cuts need to be smooth, if just left cut it can sound a bit raspy .
if you want some serious bass then start looking at a folded port design, built some large cabinets for my old mobile nightclub set up a few years ago .. longthrow deep bass.. but size matters 2 x 12 in each box
Old May 13, 2005 | 08:09 PM
BillyCabrio
bassboy
How much??
How is it??
Old May 13, 2005 | 08:24 PM
Damo V's Avatar
Damo V
As per my email
spec: 500w Max, 160w Nom, 4 ohm, Model TS-W303C
Diamondplate Foamed IMPP (Injection Molded Polypropylene) Rigilite™ Composite Cone Woofer (Titanium Grey)
One-Piece Cone Construction for Reduced Distortion
Dual-Layer Urethane Surround
Direct-to-Cone Voice Coil Mounting Ring
Conex Damper with Damper Ring
Lead Wires Integrated into Damper for High Reliability and Improved Power Transfer
Oversized Glass-Imide Voice Coil Bobbin
Projected Pole Yoke with Vented Pole
High-Energy Strontium Magnet with Bumped Back Plate
Low-Q Design for use in Small Sealed Box (1.5 cubic foot recommended)
500 Watts Max Music Power
160 Watts Nominal Power Handling
Frequency Response: 18-2,000Hz
Sensitivity (Efficiency): 93dB (1W/1m)
4 Ohm Rated
So you need a 1.5 cubit foot SEALED box per sub, an amp running 100-120 watts per channel (RMS) (400w peak), at 4ohms for a nice sensible setup
Tht spec is from Pioneer direct.. I always prefer sealed boxes anyway...
Paul have you actually mentioned its going in a cabriolet ??
Old May 13, 2005 | 08:26 PM
BillyCabrio
Cheers mate, oh and it aint - thats why i never said it
Old May 13, 2005 | 08:27 PM
Damo V's Avatar
Damo V
I stand corrected
Old May 13, 2005 | 08:30 PM
Damo V's Avatar
Damo V
martyn,
those vibe sub/amp combos are excellent value for money IMO.. Id certainly recommend them
Pat
Aug 20, 2009 12:38 AM
turbinator
Computers, Consoles and I.T.
Jul 19, 2004 04:19 PM
