read this ,new wheel bearings lasted 3 days!!
Old May 3, 2005 | 09:43 AM
morto's Avatar
morto
Default read this ,new wheel bearings lasted 3 days!!
got new front wheel bearings put in the wifes frst and ther noisy as fook after just 3 days the originals lasted 14 years
been back to the garage and ordered new ones with out even taking the car out..
andzz
Old May 3, 2005 | 09:44 AM
Over tightened?
Old May 3, 2005 | 09:47 AM
morto's Avatar
morto
think your right mate, i wud of done the job myself but on the front wheel bearings you need special tool to get them out, rear ones r easy to do
iv done the rear on my erst and ther fine so thats garages for you!
andzz
Old May 3, 2005 | 10:22 AM
GARETH T's Avatar
GARETH T
the stub axel is fooked?
Old May 3, 2005 | 10:31 AM
steviep's Avatar
steviep
There's no special tool for the front bearings, their the same as the rears, you just have to remove the brake caliper and contend with the strut
Old May 3, 2005 | 10:55 AM
morto's Avatar
morto
steviep, r u sure mate, iv asked on the fiestarsturbo.com site and thay said ther is?
thay said the fronts are very hard with out the tool, i think its a puller . and it shows one in the haynes manual
andzz
Old May 3, 2005 | 10:59 AM
steviep's Avatar
steviep
Positive, done loads of 'em, you can use a puller but it's simple enough to just drive the races out with a drift the same as the rears.
Old May 3, 2005 | 11:04 AM
morto's Avatar
morto
what a fooker i wud of done the job myself, and probaly done a better job
did you torque the bearing or do on feel? do you no the torque figure?
thanks
andy
Old May 3, 2005 | 11:08 AM
steviep's Avatar
steviep
I don't bother with a torque wrench, best way to tighten it it with mole grips.
Clamp them onto the nut and do it as tight as you can just by twisting the mole grips, then undo half a turn and retighten, don't forget the split pin.
Old May 3, 2005 | 11:11 AM
St3V3_C's Avatar
St3V3_C
Originally Posted by steviep
mole grips.
Dodgy geezer
Old May 3, 2005 | 11:16 AM
Simon's Avatar
Simon
And if the bearing wont come out with a drift run a line of mig weld on the inside of the bearing shell and it will just fall out
simon
Old May 3, 2005 | 11:24 AM
markk's Avatar
markk
simon
people never believe me when i tell them that been doing it for years and years
JoeyBoyden
Jan 4, 2024 02:36 PM
malkiemac3579
Jul 14, 2017 12:10 PM
bassboy
Aug 8, 2015 10:21 AM
fatboy billy
Aug 3, 2015 08:34 AM
muz
Aug 1, 2015 06:48 AM
