Cossie boosting problem???
Old May 2, 2005 | 12:07 PM
MickB's Avatar
MickB
Default Cossie boosting problem???
Got a bit of a problem when cossie comes on boost,it feels like its pulsing,like its hitting its boost limit and the ecu is bleeding it off,its fitted with a stage 1 chip so should do 1 bar but it hits about 10 psi and then starts to fluctuate between 10 and 15psi,never holds a steady reading,boosts up then drops down,its not harsh,just anoying.
Every thing on the engine is standard spec ,uses a 2wd l6 ecu,standard map,amal valve ect.
Thanks.
Old May 2, 2005 | 03:02 PM
Guinnless's Avatar
Guinnless
Check for a leaking bypass valve. This is connected to the intercooler and turbo inlet pipe.
Old May 2, 2005 | 07:43 PM
MickB's Avatar
MickB
Not that i dont think,just fitted a brand new bailey 1.
Cheers mate.
Old May 3, 2005 | 01:34 PM
Guinnless's Avatar
Guinnless
Check wastegate actuator is set correctly. The correct tension is 'half a hole' i.e. you can see the wastegate arm pin but it needs half a hole to pull it over. IYSWIM
Make sure there are no other air leaks. Listen while the engine is running and/or use a vac gauge.
Old May 3, 2005 | 04:46 PM
davidreader5's Avatar
davidreader5
HI,
All above, but also check wiring to amal valve is good, and if possible try
with the amal valve disconnected,run compressor pipe off amal valve straight to actuator,(c) at amal valve so you will see just actuator pressure
if the actuator boost pressure is stable, and the wiring from the ecu is good try another amal valve.
DAVE R
Old May 4, 2005 | 03:14 PM
MickB's Avatar
MickB
Wastgate ok,checked for leaks,everything sounds/looks ok.
I've got a feeling its amal related so will check that.
Thanks for the help
Old May 5, 2005 | 01:41 PM
MickB's Avatar
MickB
Fitted new amal valve,sorted the problem
Cheers for the help
Old May 6, 2005 | 09:15 AM
Guinnless's Avatar
Guinnless
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
RsS2daz
Aug 14, 2015 05:26 AM
sjssms
Aug 2, 2015 07:01 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
