Greys without LIVE map ?
Old May 1, 2005 | 10:19 AM
neil d's Avatar
neil d
Default Greys without LIVE map ?
Is it possible to run a cossy engine on grey injectors without having the car live mapped ? the car has all the bits needed low comp etc ????
Old May 1, 2005 | 10:21 AM
Ginge !'s Avatar
Ginge !
just finding my feet
colins is the only place i know that does off the shelf chips but they do overfuel on idle alot hence why most only live map
Old May 1, 2005 | 10:22 AM
Dilly's Avatar
Dilly
when i 1st had my car rebuilt - A1 rally sport gave me an of the shelf chip for greys
Old May 1, 2005 | 10:23 AM
Ian M's Avatar
Ian M
definately not recommended.
Old May 1, 2005 | 10:26 AM
neil d's Avatar
neil d
why you say that ian ?
Old May 1, 2005 | 10:29 AM
Ian M's Avatar
Ian M
the injectors are so big that the chip only has to be a few milliseconds out on the fuelling for it to cause irrepairable engine damage ie: bore wash and it doesnt take very long to do either.
Old May 1, 2005 | 10:33 AM
neil d's Avatar
neil d
i suspected that ian my car has just blown its 3rd engine in 18 months last night after trying to run greys without a live map not a happy man
Old May 1, 2005 | 10:41 AM
Ian M's Avatar
Ian M
i would be taking it to msd to be set up, checked and mapped properly certainly cheaper than fixing engines.
Old May 1, 2005 | 10:43 AM
Uncle Henry's Avatar
Uncle Henry
define 'live' map though?
my car was set up by Stu/Kenny and wasnt live mapped as such, on the other hand it was properly set up (they replaced the chip as they deemed it unsuitable to drive nicely on the road) and checked/road tested it. It drives heaps better since.
So it wasnt an 'off the shelf' chip but it also wasnt live mapped
Old May 1, 2005 | 10:49 AM
Ian M's Avatar
Ian M
live map = mapped specifically for your engine and ancilliarys done this way the car will allways run and perform much better than a one size fits all chip.
uncle henry was yours on greys.?
Old May 1, 2005 | 10:54 AM
Ginge !'s Avatar
Ginge !
stu wrote as custom chip for mine too but wasnt a live map either
Old May 1, 2005 | 10:56 AM
Ian M's Avatar
Ian M
Originally Posted by b19bal
Stu wrote as custom chip for mine too but wasnt a live map either
neither was it on greys.
Uncle Henry
yeah mines on greys, low comp, bd10's etc. It went for a check up before I exported it to Australia.
Kenny test drove it and decided it wasnt very road friendly, found there was no ignition advance curve to speak of, so they supplied a new chip and set it up from there. It was not 'live mapped', just setup and tuned on the road with a gas analyser up its arse to ensure correct fueling etc.
drives shitloads better and Im happy in the knowledge its not running lean and about to die! (even if I did freeze to death in the waiting room for hours!!!! )
Andreas's Avatar
Andreas
Aint that borewash problem on greys a bit inflated? Or does it take just a little over fueling for it to happen?
I remember it was a hot topic back in the nineties. I ran greys back in 98 on a stage2 conversion without any problems at all.
Consumed less fuel than my current Bayjoo conversion.
It was checked over with a lambda meter though so thats perhaps why it ran fine without problems.
Old May 1, 2005 | 10:58 AM
Ginge !'s Avatar
Ginge !
i never knew uncle henry lived in ausie land
when did that happen
Old May 1, 2005 | 11:02 AM
Uncle Henry
When I bought my 3 door I checked the CO myself at my local mot station..it was around 7% at idle!! I spoke to Collins as I was getting some bits off them at the time and they said thats normal, I asked about borewash driving it round own etc - they gave me a funny look and said I shouldnt be driving it round town as its "not that sort of car".
I forget what the CO was it was redone at msd but it was under 3% anyway and a hell of a lot more driveable - it 'shunted' if you were in at a slightly higher gear than the speed of the car allowed. it does none of that with the new chip.
Old May 1, 2005 | 11:05 AM
Ian M's Avatar
Ian M
i ran an off the shelf greys chip once and melted the engine after 200 miles.
the engine had only done 1200 from a new rebuild.
on stripping the engine down to build it again the amount of bore wash was phenominal.
so in conclusion the chip fuelled far to much right through the range and then to cap it off it had way to much ignition advance at the top which promptly disposed of three pistons.
Old May 1, 2005 | 11:08 AM
Ian M's Avatar
Ian M
the co reading on mine now is 0.6% and it drives better than a standard car.
Old May 1, 2005 | 04:58 PM
neil d's Avatar
neil d
ian seems to be a similair story have lost the third engine after about a thousand miles after running in .every thing was checked to make sure it was ok electirly and mechanicly .was doing about 140 and it just missed and all over running a Armed chip and ironically had decided to go back to greens too
Old May 1, 2005 | 09:02 PM
Ian M's Avatar
Ian M
thats the one neil bit of a hesitation come off the throttle look in the mirror james bond type smoke screen. pistons melted, hence why its best to have them mapped properly.
Old May 1, 2005 | 09:17 PM
john's Avatar
john
Oh no not again neil
Least you got to a thousand this time though lol.
I have said in the past to get it live mapped if on greys.
Proper gutted for you m8
Old May 1, 2005 | 09:32 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Re: Greys without LIVE map ?
Just re-read your question and realised the at the end, I assume this all went wrong for you then. Sorry to hear the bad news...
Old May 1, 2005 | 10:21 PM
neil d's Avatar
neil d
Yes frog it did but should be used to it by now taking head off tommorrow to inspect the dammage one thing for certain its going back on greens and a set up at MSD before any more high speed runs
yes John again but to be honest was never confidant in the engine so not to pissedoff
Old May 1, 2005 | 11:41 PM
morcheen's Avatar
morcheen
my bruv ran his on greys for 9 years without any problems
how long has live mapping been around ?
Old May 1, 2005 | 11:44 PM
CraigN's Avatar
CraigN
my collins greys chip was wank they had just robbed an old rally car map
my car was mapped by karl Norris best £250 ive spent on it
Old May 1, 2005 | 11:45 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
neil
what did i telllllllllllllllll theeeeeeeeeeeeeeeeeeeee get it mapped propper as u know what i think of swillington and its been prooved again he is wank msd 1 live map and 1 bill job done
Old May 2, 2005 | 08:45 AM
neil d's Avatar
neil d
yes gus you did had decided to go back on greens till had the cash to map it but its put me back 12 months again never had 100% faith in that engine so not so pissed off . you live and learn
Old May 2, 2005 | 09:43 AM
Rs Gus's Avatar
Rs Gus
yes u do i supose after 4 engines u do i got a nice escossie for sale cheap
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fil
Sep 30, 2015 12:08 PM
jay030787
Sep 25, 2015 01:38 AM
