cold start valve
Old Apr 27, 2005 | 02:33 PM
doggydowg's Avatar
doggydowg
Default cold start valve
Hiuya guys i think mine might be duff as my fuel consumptoin is realy poo i want to disconect the sensor so it does not work anymore, where is the sensor located?
Ive lookd on back of manifold but it seems like there is 2 im not sure which one it is both are around the same area right in the middle of manifold at the back any tips pics etc much appricated.
Paul.
Old Apr 27, 2005 | 02:46 PM
glenis's Avatar
glenis
On an MFi inlet manifold it is the green plug on the right hand side of the manifold....
right hand corner towards the top...
ECT is blue plug at the back/bottom on EFi inlet manifold, and i think MFi too
Old Apr 27, 2005 | 03:17 PM
doggydowg's Avatar
doggydowg
i thouht the green one on the right was knock sensor i am running mfi just want to disconect the cold start valve sensor.
what is an ect did you mean act?
chears Paul.
Old Apr 27, 2005 | 03:22 PM
glenis's Avatar
glenis
yeah sorry, green one is knock sensor
ECT is engine coolant temperature sensor, well its on EFi manifolds... cant remember about MFi
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
The green sensor/plug IS the knock sensor. The blue plug IS the cold start valve. Brown is thermo time switch etc. .
if the injector is leaking when fully warmed up it may suggest it needs replaced other than just unplugging it, so not an electrical fault but mechanical with the injector.
Old Apr 27, 2005 | 03:29 PM
doggydowg's Avatar
doggydowg
ive heard the cold start valve gets its reading from the etc so if it reads from this and that is wrong then itd be on all the time.
I want to unplug them all i dont like all these idiot proof sensors, i take it the blue and the and the brown plugs are the two plugs round the back of the manifold in the middel then in which case i can just disconect both?
where its al grubby round there i cant see what color they are hense why i am asking if i can just discoinect both?
not sure that there is a leak my car is just realy bad on petrol and i only use on sunny days so might aswell disonect it as i dont need it and its just another thing that may be wasting petrol.
muffster
13
Sep 3, 2015 09:40 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Sultzi
12
Aug 16, 2015 01:08 PM
Archiejay
Aug 12, 2015 12:07 PM
Red_bull
Aug 9, 2015 08:34 AM
