BLEED VALVE HELP!!!!!!!!1
Old Apr 26, 2005 | 02:00 PM
phoenix's Avatar
phoenix
Default BLEED VALVE HELP!!!!!!!!1
Found a bleed valve and was wondering which direction i turn it to release more boost as i dont really wnaa detonate the car after 2 days of owning it?
and how much should i turn it
Old Apr 26, 2005 | 02:18 PM
cooler king's Avatar
cooler king
i dont think you should mess with it!!!!!!!!!!
Old Apr 26, 2005 | 03:43 PM
davidnormanuk's Avatar
davidnormanuk
To run more boost you turn the bleed valve out but you might need to set it up if you run too much.
What's the spec of the car?
Dave
Old Apr 26, 2005 | 03:52 PM
cooler king
id get it done professionally! mine is being done tommorrow, only putting it to original boostr but my fueling is allover the place as is the timing!
Old Apr 26, 2005 | 04:43 PM
rs-nut-john's Avatar
rs-nut-john
ive heard to many horror storys 2 do with bleed valves, there are bad news if u get it wrong. Ive been out and got a new amal valve from ford to save me going done this dodgey road, plus i heard that amal valves help it boost better... ..not too sure on that 1 like...any thoughts...???????
Old Apr 26, 2005 | 08:34 PM
cooler king
i havent a clue!!!!????? i heard the horror stories about the bleed valves too!
Old Apr 26, 2005 | 09:35 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
I just found a bleed valve on my newly purchased RST but i've been advised to leave it be!!
Old Apr 26, 2005 | 10:22 PM
AKRS1's Avatar
AKRS1
One thing i dont understand is whats the purpose of the amal valve as i have the amal valve connected, bleed valve connected and a -31 actuator. So what are all these things there for
Old Apr 26, 2005 | 10:37 PM
GrimmeRS2K's Avatar
GrimmeRS2K
some people does use this way, would proberly work better using just one, either adjust the rod and use the amal valve..... i always used the amal valve, and found they provide a more solid boost when come in, but my tuner disconnected it, and used a bleed valve to adjust the boost, they are perfectly safe untill you turn the boost up yourself and blow it up.... get it done by a tuner and it will be fine
most peoples amal valve dont work anyway and dont know about it!!
Old Apr 26, 2005 | 10:40 PM
AKRS1's Avatar
AKRS1
I have noticed though that if i disconnect the amal valve it will only around 10psi and when i connect it, it will run 14psi
Old Apr 26, 2005 | 11:04 PM
GrimmeRS2K's Avatar
GrimmeRS2K
it will do, that means yours work for one thing, with the wire disconnected its just a non-adjustable bleed valve,
one good about the amal valve is a cheap 2 stage boost installation!
Old Apr 27, 2005 | 08:19 AM
AKRS1's Avatar
AKRS1
Yes i did have a 2 stage boost switch set up in the car but was told it was better for more high powered cars
Old Apr 27, 2005 | 10:41 AM
db's Avatar
db
The amal valve has 3 pipes and is electrically connected to the ECU:
-from the turbo
-to the actuator
-to the air filter housing
When the turbo starts to produce boost, the pressure coming from the turbo will be diverted into the airbox, because the amal valve is powered by ECU.
This means boost will rise quickly, because no air is going to the waste gate actuator.
At a certain boost level (programmed in ECU) power is taken away and all pressure from the turbo is sent to the actuator, which will then take over completely.
So the amal valve is a way of getting the boost started as quickly as possible.
If you disconnect it, all boost will be diverted to the actuator, therefore boost will build slower, because the spring will give way already in early stages of boost build up.
This is the story for a standard car !!
Old Apr 27, 2005 | 10:45 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
db,
Old Apr 27, 2005 | 01:38 PM
RS_JAY's Avatar
RS_JAY
I had a bleed valve, but took it off and put the amal back on. Mine goes to 18 psi & holds but very rarely go to 18. So ive had no reason to connect the bleed valve back on.
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
markk
Sep 9, 2015 08:11 AM
