-1.1 psi with engine not running?
I keep getting a reading of - 1.1 psi MAP from my SEC monitor even with the engine not running (just power on). Is this a ground issue maybe? I just bought a new 3 bar MAP sensor and still the same. Also the monitor is set correctly to 3 bar.
I also have a spa boost gauge and it reads 0.0 at the same point and I get 26.1 max boost with that and only 21.0 psi on the SEC Monitor.
Anyone else with anything like this?
big_Rad
Sep 15, 2017 09:36 AM
Zoggon
Aug 10, 2015 10:39 AM
