zetec turbo questions.
Old Apr 18, 2005 | 10:30 PM
radiant red's Avatar
radiant red
Default zetec turbo questions.
Just got hold of a 1.8 zetec motor with a snapped cambelt, paid a tenner for it so im well chuffed.
Now then, i know i want to completely rebuild the bottom end using suitable low comp pistons, do some work on the head ports and put a suitable set of cams in for a big power turbo lump.
What i need to know is what engine managment i can use without spending silly money, what pistons are suitable and if there is a cam profile for a blown zetec.
Any info is well appreciated
Regards
Pete.
Old Apr 19, 2005 | 12:08 PM
radiant red
I would like to use fezzy rs managment. anybody done this?
Old Apr 21, 2005 | 02:58 PM
swrsturbo's Avatar
swrsturbo
Did you ever finish that cut-out bumper mate?
Old Apr 21, 2005 | 08:12 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
fezzy management will run fine, im using OFAB on mine as are others,
im using accralite pistons, after a few probs i finally sorted em
the cams havent been decided yet, theres another thread about that somewhere, atm im using 115 cams but i do have a set of 130's to go in
Old Apr 24, 2005 | 10:40 PM
radiant red
Yes mate, got a local body shop to finish it off. Im usally round cas on a weekend, show you it sometime.
Old Apr 25, 2005 | 11:54 AM
radiant red
Is OFAB the best choice over OFAC, what are the bnefits
pete.
Old May 2, 2005 | 10:45 AM
tonyturbo's Avatar
tonyturbo
i use ofab aswell. some say ofac is better. i dont know the reason for this!!!!!
Old May 3, 2005 | 05:55 PM
radiant red
are you running a zetec turbo?
i will be doing the work to the head ports myself, is it best to match them to the manifolds ( cvh )
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
