Rs turbo release bearing / clutch issue
Old Jul 12, 2025 | 02:38 PM
fatty's Avatar
fatty
Default Rs turbo release bearing / clutch issue
Guys,
got my rs turbo back together and now when I press the clutch pedal, the clutch arm on the gearbox seems to ‘jam’ on. It’s like the release bearing is getting stuck in the cover plate ?
i fitted a release bearing I had lying around for an escort ..think I’ve f%^*d up here.
has anyone else has this ?
thanks
Old Jul 13, 2025 | 12:18 PM
boost monster's Avatar
boost monster
I’ve known the ones with plastic tabs to break. I only use the metal ones now. I think your taking the box out again.
Old Jul 13, 2025 | 12:58 PM
fatty's Avatar
fatty
Thank you for your response !
Yeh , i was hoping for the gear box fairy to do it over night but its still the same.
Only thing I remeber is that the contact 'ring' on the release bearing I fitted was narrower that the RS one , only thing i can thing off that is different.
Originally when i pressed the clutch, I couldn't get the gears because it was grinding then i checked and the arm was 'stuck' as mentioned.
RSargie
May 7, 2010 10:19 PM
Rich_bloor
13
Sep 28, 2009 10:15 PM
efiste2
Apr 13, 2007 02:23 PM
