Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Mk3 Escort 1.6 CVH VV Carb
Old Mar 13, 2025 | 10:50 PM
rustyvolvo's Avatar
rustyvolvo
Default Mk3 Escort 1.6 CVH VV Carb
I have a Mk 3 Escort Cabrio with a 1.6 and a VV Carb. I was looking at some options along the lines of a non Ford CFI style conversion. Does anyone have some dimensions for the base gasket between the carb and the intake manifold? Looking at bolt spacing and Hole size in the manifold for the single barrel. Could do the Weber swap but before I go that way I was thinking a single point injector would work better. Thanks.
Old Mar 14, 2025 | 10:12 PM
Expo1's Avatar
Expo1
For the base gasket, bolt spacing and hole size can vary. If you're leaning toward a single-point injector setup, it could improve fuel delivery over a carb, but the Weber swap is also a good option. You might need to check with a supplier for exact gasket dimensions [url=https://fora.warszawa.pl/]😊
Old Mar 15, 2025 | 01:59 PM
rustyvolvo's Avatar
rustyvolvo
Are you saying that the 1.6 CVH for that year came with different kinds of VV carbs? From the Haynes manual it just looked like one was available. Would the flange on the carb change between versions? Thanks.
kalf
Aug 23, 2023 09:25 AM
Fiestamk31.6cvh
Dec 25, 2020 05:17 PM
adampotten
Jan 18, 2013 07:44 AM
Calmn
Dec 2, 2012 09:02 PM
enduro.nick
Apr 23, 2012 06:59 PM
