Ford sierra 2.0 dohc engine
Old Jun 6, 2024 | 09:41 PM
mexico boi's Avatar
mexico boi
Default Ford sierra 2.0 dohc engine
Hi everyone
Would anyone on here be kind enough to try and help me ?
I have fitted a new timing chain to my 2.0 dohc 8v and I have followed the Haynes manual and also the info on this website .
Have the crank at 6 o'clock tdc and the cam sprockets set at a quarter 3 tdc . My engine turns over by hand 2 full turns and all marks line up to tdc . But my engine won't start .
Is there anything I'm not doing correct ? Don't want to keep cranking engine over incase I wreck it.
Really hope someone on here can help.
Thanks
Old Jun 7, 2024 | 07:11 AM
XR2's Avatar
XR2
Don't know anything about the DOHC 8V but it sounds like you succeeded in changing the new timing chain and setting up the engine!?
Perhaps there's something else missing. CPS not connected? Anything else maybe? Does it get fuel and a spark?
Old Jun 7, 2024 | 12:10 PM
mexico boi's Avatar
mexico boi
Hi thanks for your reply. Everything is connected that should be connected and I have tried everything I know and I still can't get the engine to go plus I have followed all the info on this site about the timing marks and also I have followed the Haynes manual for the timing marks and I still can't get it the engine to go . Really wish someone could tell me what's wrong
Old Jun 7, 2024 | 01:50 PM
XR2's Avatar
XR2
Well???
Old Jun 7, 2024 | 04:23 PM
mexico boi's Avatar
mexico boi
Yes getting fuel and spark
Old Jun 7, 2024 | 05:35 PM
Guinnless's Avatar
Guinnless
Just recently done mine. Hope these pics help.
Have you released the tensioner by pushing it down?
Old Jun 8, 2024 | 03:48 PM
mexico boi's Avatar
mexico boi
Hi thanks for your reply and photos of your 2.0 dohc engine . Yes I have released the chain tensioner and the engine turns over by hand so no valves hitting pistons. Engine also turns over on the starter but it just won't start . I have checked all spark plugs and I have good spark also have checked fuel coming to engine and it is getting fuel
In your photo of the cam sprockets timing marks are not level with the edge of the cylinder head ? Is your engine at TDC with your cams like this?
I took the wiring loom of the injectors to take engine out and not having marked the connectors I'm not sure if I have them on the right injectors .
Would you have any photos or info on this ?
Old Jun 9, 2024 | 08:09 PM
Guinnless's Avatar
Guinnless
The picture was taken when the engine had moved slightly when tightening the crank bolt up so the marks are not level with the head but are opposite each other at 180°.
The injector plugs are paired in the loom as 1&2 and 3&4 so you may have transposed which would explain fuel and spark but not starting. It may be worth swapping each pair over and seeing if it starts. No photos of this sorry.
As you say TDC on the crank is at 6 o'clock and the cam pulley marks should be at 9 o'clock on the inlet and 3 o'clock on the exhaust IIRC the exhaust mark should have a slight droop, this is shown in the Haynes manual.
Check plug lead order . The dizzy cap terminals are numbered so it should be easy.
Old May 27, 2025 | 11:21 AM
sierra3dr's Avatar
sierra3dr
I wonder how he got on? I have just noticed this post. Can admin supply me with an email for OP?
kosienutter
102
Apr 9, 2020 06:14 PM
Pegasus79
May 21, 2010 09:24 PM
bil
Nov 23, 2007 05:56 PM
