Camber correction plates with drum brakes
Old Jul 6, 2023 | 06:43 PM
SindreK's Avatar
SindreK
Default Camber correction plates with drum brakes
Hi.
First time posting.
I am trying to install these on my lowered 1982 Sierra 2.0L.
https://creationsmotorsport.com/catalog/product/view/id/3028/s/0-5-deg-negative-camber-correction-plates-for-ford-sierra-cosworth-scorpio/
Instructions say "mounted between the axle and hub" and "Can be mounted on vehicles with disc or drum brakes on the rear axle."
Should they me mounted between the arm and the drum backplate or between the backplate and bearing carrier?
they don't fit in the first scenario, and in my mind the second scenario would put an angle between the brake shoes and the drum, no?
​​​​I've tried searching, maybe there's something here I don't understand.
Old Jul 10, 2023 | 09:27 PM
xr_craig's Avatar
xr_craig
I would think between the arm and backplate otherwise as you say it would cause issues
Old Jul 11, 2023 | 07:00 PM
Robzilla's Avatar
Robzilla
Default Correction plates
Take the hub off and they go behind the hub,between the bearing and hub. don’t forget the left hand thread on one of the driveshafts( can’t remember which one lol)
Old Jul 15, 2023 | 03:26 PM
Marc sierra's Avatar
Marc sierra
They should go in between the arm and the brake back plate.
Why don’t they fit that way?
Old Jul 15, 2023 | 05:20 PM
Robzilla's Avatar
Robzilla
got any pics
Old Jul 15, 2023 | 05:23 PM
Robzilla's Avatar
Robzilla
I know these are disc brakes but shows the plates clearly
Old Jul 17, 2023 | 09:34 AM
Marc sierra
No I don't have any pictures. But like you said yourself, if you put them in between the bearing housing and the brake backplate the brake drum will be on an angle relative to the brake shoes which isn't the way it should be.
Old Jul 17, 2023 | 09:49 AM
SindreK's Avatar
SindreK
I figured it out. The problem was the correction plate didn't fit inside the brake backplate. Backplate curves a bit, kinda wraps around the arm where they are mounted. I just trimmed the plates, cut off the corners basically. Regret not taking pictures now...
Old Jul 17, 2023 | 10:10 AM
Marc sierra
Nice that you fixed it. I guess most of the plates are used in combination with disc brakes, in which case you wouldn't have the problem, as the splash guards on disc brakes are not curved towards the arm.
Anzie
Oct 14, 2010 05:02 PM
turbocat
May 25, 2008 10:04 PM
Disabled Account
16
Mar 27, 2006 03:33 PM
Gra
Jan 16, 2005 03:53 PM
