4wd Cosworth Map Sensor Voltage
Old Sep 10, 2022 | 03:31 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default 4wd Cosworth Map Sensor Voltage
Finally got around to playing with the cossie again.
I’m getting bad over fueling on idle and it’s really lumpy when reved. Plugs soot up within 30 secs of running.
it’s a 2 bar map sensor and im seeing 2.14v ignition on (book says 2.2 so that’s okay). At idle it’s around 1v and will increase when reved but erratic and jumpy. Book says should be 0.25 to 0.6v at idle. Could this difference of 0.4v cause my overfueling? I have literally changed everything else except the MAP sensor.
(I’ve test across ECU pin 11 (ground) and pin 15 (output voltage). Input voltage at 30 is 4.94v so that’s fine as should be 5v)
Cheers in advance
Old Sep 10, 2022 | 10:51 PM
james kiely's Avatar
james kiely
have you checked your fuel pressure regulator jim ?
Old Sep 11, 2022 | 01:11 AM
Jimboxr4x4's Avatar
Jimboxr4x4
Hi, yes it was 3.5 bar at the rail. Also new coil, ignition amp, distributor cap and rotor, plugs, CTS, CPS, phase, ACT. Also tested TPS and was fine. MAP is the only sensor I haven’t physically changed.
Old Nov 23, 2022 | 07:17 PM
RHarvey's Avatar
RHarvey
Hi Jim,
Just a quick one, if you haven’t cured this yet, I had the same issue. Take the vacuum pipe off the fuel pressure regulator (the one which joins onto the intake manifold opposite cylinder 3), and start the car, if you’ve got fuel coming out of the regulator then it’s had it, the diaphragm inside the regulator will be shot, and allowing fuel down the vacuum pipe and into the manifold, therefore bore washing the cylinders, just like mine was! Let me know how you get on.
Old Dec 31, 2022 | 10:29 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Originally Posted by RHarvey
Hi Jim,
Yes, what you describe was exactly what I had found - fuel in the vacuum pipe from the FPR. New regulator and running nice now.
MK2 COSWORTH
Jun 26, 2012 12:08 PM
jemis
Jul 17, 2009 05:10 PM
Paulo P
May 31, 2008 10:17 PM
magenta4x4
Aug 4, 2007 01:56 PM
Feb 28, 2004 02:06 PM
