Would a MAP sensor cause poor idle?
Old May 31, 2008 | 06:15 PM
Paulo P's Avatar
Paulo P
Default Would a MAP sensor cause poor idle?
I'm just in the middle of a turbo change & stage 3 so I've just changed the turbo, intercooler & map sensor (3 bar) and run the car up to temp to check for water leaks. I haven't fitted the injectors yet so the car is on the NMS gunship map at the moment.
I have an erratic idle so I wondered if the different MAP sensor could be sending it confusing signals? Obviously I will not be driving the car until the injectors & chip are changed
Thanks
Old May 31, 2008 | 06:19 PM
Mark Shead's Avatar
Mark Shead
Yes it will.
Mark
Old May 31, 2008 | 06:20 PM
Paulo P's Avatar
Paulo P
Thought as much. Thanks for confirming it Mark I can carry on now
Old May 31, 2008 | 06:23 PM
Jim Galbally's Avatar
Jim Galbally
2bar map sensor reads -1 to +1 as 0v - 5v
3bar map sensor reads -1 to +2 as 0v - 5v
so each dige a different signal at different pressures, and the ECU can't tell the difference
Old May 31, 2008 | 07:08 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
..yeh deffo.....i had a problem after my re-build......just wouldn't run propperly
Old May 31, 2008 | 07:25 PM
Paulo P's Avatar
Paulo P
Chip and injectors should be in early next week so fingers crossed it'll run properly again. I was a little worried because I've changed quite a few things and just wanted to check for water leaks abd refil the system, maybe I should have waited until it was all on
Old May 31, 2008 | 07:42 PM
xr4x4rs's Avatar
xr4x4rs
why not just put your old map sensor back on then the car will run fine
Old May 31, 2008 | 08:20 PM
Paulo P's Avatar
Paulo P
Because I'm fitting the injectors and chip next week, this is my 2nd car and doesn't get driven The only reason I started it today was to check for water leaks and to bleed the system, it was only run on idle so I knew it wasn't a problem.
Old May 31, 2008 | 10:17 PM
Jim Galbally
please, dont drive it with the wrong map sensor on, it's pointless, just put the 2bar back on, its not like it's hard to swap... lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
jay030787
Sep 25, 2015 01:38 AM
