Engine Locked up
Old Mar 6, 2022 | 02:53 PM
Bransby's Avatar
Bransby
Default Engine Locked up
Hi, got the RS fired up with a brand new lump…. Runs for 1 or 2 mins with decent oil pressure etc then bang!! And just stops dead. Tried to turn start motor n nothing.
stripped starter and it had seized up and was damaged so guessed hadn’t disengaged n locked engine.
New starter motor fitted and she fires up and makes a god awful like scraping sound.
Take all plugs out and spin on just starter motor and spins over without a noise.
what could of happened?? Don’t want to go down wrong road. But have a awful feel the engine I bought is goosed now.
thanks
Old Mar 6, 2022 | 02:56 PM
haz87's Avatar
haz87
Did you inspect the flywheel to make sure it hadn't taken a few teeth with it when it locked up? Could be shite floating round in the bellhousing and bashing into the flywheel/clutch assembly?
Old Mar 6, 2022 | 03:27 PM
Bransby's Avatar
Bransby
Hi mate, yea all teeth on both starter and flywheel were fine… with new starter fitted and no plugs the whole engine spins smooth as can be… the second it fires up under its own steam it makes this horrible sound like a ring scraping… hard to explain but it’s horrible and you turn it straight off.
Would a starter locking up be strong enough to stop an engine dead on tick over?? Or could the starter just be a coincidence 🙈
cheers
Old Mar 6, 2022 | 05:16 PM
BIG LEE's Avatar
BIG LEE
is top end ok ie camshaft etc..
Old Mar 6, 2022 | 06:26 PM
Bransby's Avatar
Bransby
Hi mate, not pulled head but taken rocker cover off and turned engine over a spanner and seems fine… if you spin it on starter it’s smooth as can be… once you connect plugs up and it fires up the horrible sound starts… sounds like scraping metal.
no idea what it could be, going to have to strip engine I guess but don’t want to go down wrong road and do a load of work for nothing.
cheers
Old Mar 6, 2022 | 06:57 PM
BIG LEE's Avatar
BIG LEE
is alt brand new? or recon? maybe check that aswell as ive had one that made horrible noise like when running
Old Mar 6, 2022 | 07:14 PM
Bransby's Avatar
Bransby
brand new alternator, did yours only make the noise once engine fired up?? strange thing is it only started making this noise since the engine locked up…. I’ll pull belt and give it a try before I strip engine, I’d be so happy if it was the alternator.
cheers
Old Mar 6, 2022 | 07:32 PM
BIG LEE's Avatar
BIG LEE
Yeah it never stopped engine but its easyer then pulling motor to bits lol..
Old Mar 7, 2022 | 09:30 AM
Bransby's Avatar
Bransby
Big Lee,
I could kiss you pal… it was the alternator!!! No idea how the starter motor jamming the engine somehow took out the alternator at exactly same time but Im so glad I didn’t pull the engine back down…. Thanks mate
Old Mar 7, 2022 | 11:29 AM
BIG LEE's Avatar
BIG LEE
No trouble pal... i build engine etc myself etc and i remember my alt man it was fully recon unit so i paid for anyways and that actn on so i took it back about 3 times in total like.. glad its sorted tho
Fil
May 13, 2019 09:08 PM
rustyboy
Ford Mondeo Including ST
Mar 6, 2014 07:55 AM
RichieST
Nov 16, 2011 06:53 AM
marksrsorion
Apr 9, 2009 03:54 PM
turbo.jon
May 5, 2004 05:04 PM
