Un-bending a bent exhaust
Old Nov 14, 2021 | 12:40 PM
Carlitos's Avatar
Carlitos
Default Un-bending a bent exhaust
Hi all. I've got the Zetec engine in my Escort now and went to fit a Magnex exhaust system I picked up a few years ago second hand. While the seller didn't tell me this it appears the exhaust is bent, probably it got rear ender or something like that. When trying to fit the backbox it's at an angle hitting the bumper and tyre.
Does anybody have suggestions on how I might be able to un-bend this myself? Probably the answer is I can't but doesn't hurt in asking!
The part on the right which the backbox attaches to needs bending. You can sort of see where it kinks at the bottom of the s-bend
Old Nov 14, 2021 | 09:42 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Heat is probably the key and hope it has a memory when you bend it back, I don’t fancy your chances though and may be easier to cut out the bad but and weld in new…if you can’t do it then an exhaust making shop might but most will want to make new.
Old Nov 14, 2021 | 10:17 PM
Carlitos's Avatar
Carlitos
Thanks. I was thinking it's way out of my depth. I'll give some local shops a call in the week.
Old Nov 15, 2021 | 09:30 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
Its a bit of a bodge but in theory you could cut a small cheese wedge out of the straight and then weld up the gap as it would bring the end pipe back in line.
Old Nov 16, 2021 | 04:59 PM
Carlitos's Avatar
Carlitos
That's not a bad idea. I called a few custom exhaust places and none of them are interested without getting the car in their shop which is understandable. I've contacted Collins Performance who have given me some details on Mongoose exhaust system which comes in sections similar to the Magnex. I'm still waiting for their reply if I can buy just the single section. If so then I think that's my solution (if it isn't mega dosh). If not then I might have to bodge cut & weld like you said. This project has been going on for so long I just want it on the road. I can sort a proper replacement out another time.
Old Nov 16, 2021 | 06:22 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Cool, I am no pro welder but can have a go if you cannot.
Old Nov 18, 2021 | 09:23 AM
Carlitos's Avatar
Carlitos
Thanks mate, appreciate that. I've used a welder only once before and the weld would probably be laughed at by all! Was fun doing it though.
I've contacted a couple of companies regarding Mongoose exhausts. Apparently they are still manufactured and I can buy just the section needed however there are long delays in manufacturing it, Larkspeed recommended I look for a custom replacement as they can't even say when the part would be available. I'm going to have more of a hunt around.
Old Nov 20, 2021 | 11:09 PM
visa_broke's Avatar
visa_broke
10 Year Member
Just search ebay, they come up very often for rs turbos etc. I bought a full rs turbo system for fifty quid ages ago just to store incase I get a rs turbo again.
L1AM_RS
11
Apr 30, 2016 08:24 AM
woodz77
Jul 9, 2007 06:05 PM
cos im worth it
Ford Escort RS Cosworth
13
Mar 6, 2007 11:03 PM
Adam_BlackRS
Motorcycle Chat & Sales
Sep 14, 2006 01:29 AM
Jasesapphy
15
Dec 13, 2005 09:26 PM
