'06 Focus, DTC engine codes problem
Old Aug 22, 2021 | 05:25 PM
Vikane's Avatar
Vikane
Default '06 Focus, DTC engine codes problem
I have had an issue with my '06 Focus 1.6 TDCI for a while.
Several DTC's are detected, but replacing the sensors involved with DTC codes don't do anything.
The codes are:
P0100 Mass/Volum air flow A error
P0102 MAF sensor circuit low input
P0113 IAT Sensor circuit high input
Has anyone experienced other systems that could cause these codes ?
Could it be a problem with the EGR or the DPF system that are causing these codes ?
Any help is much appreciated.
Old Aug 23, 2021 | 07:04 AM
oldford's Avatar
oldford
These faults could be the result of a wiring problem, particularly a missing (common) ground.
No other part (like EGR or DPF) can cause the P0113, because the high signal means stands for a very low temperature.
Old Aug 23, 2021 | 07:22 AM
Vikane's Avatar
Vikane
Thanks for your reply.
I have tried to locate and check all visible ground connections, but it might be one that I have missed.
Any chance I could find a complete overview for all earth connections for this car somewhere ?
JimboM
May 27, 2021 08:37 AM
Cardie
Apr 4, 2015 10:20 PM
mickmusson
Ford Focus Diesel
Aug 23, 2014 07:43 PM
Sp3no
Sep 25, 2009 05:48 PM
paceo
14
Mar 28, 2007 04:31 PM
