Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Cylinder 3 misfire p0303 bmax
Old May 31, 2021 | 02:27 PM
Chrisb1987's Avatar
Chrisb1987
Default Cylinder 3 misfire p0303 bmax
Hi guys I need some advice please...
I have got a ford bmax 2013 1.4 petrol. Engine has got 42k on it
I've got my engine man light on.. code p0303 cylinder 3 misfire.
I've already replaced ignition coil, spark plugs, ht leads... engine management light came back on approx 1 week later.
I've had a diagnostics and compression test done ... all firing correctly no issues detected.
Changed the fuel injectors over (3&4) engine management light came back on later the same day... still same code.
I've been advised the next stage is testing the ECU and electrics (dont have a clue where or how to remove ECU)
Any other ideas or thoughts on this, the ECU idea sounds very expensive and I have got the Joy's of a MOT in the next couple of months so need to get to the bottom of this fast.
Any help is appreciated - thanks in advance
Old Sep 15, 2021 | 08:10 AM
rayben's Avatar
rayben
A vacuum leak can cause p0303 also.
Old Sep 16, 2021 | 09:45 PM
GVK.'s Avatar
GVK.
Diagnostics should have shown up high fuel trims if an air leak, take it to some one who's old chool just nt a code rader!!!
Rob33
Feb 12, 2016 06:46 PM
jb_ladva@hotmail.com
Jan 20, 2014 04:27 PM
craigos
Jul 28, 2012 01:12 PM
Grantcos
Jun 25, 2011 09:58 AM
HSimpson
Ford Focus RS
12
Aug 22, 2010 11:45 AM
