Ford Ka ST170
Old Feb 21, 2021 | 04:33 PM
Kristjankae's Avatar
Kristjankae
Default Ford Ka ST170
Hi!
First sorry for my bad english.
I'm going to swap Focus ST170 engine to mk1 Ford Ka.
First at all: will it fit with original ST 6 speed getrag gearbox?
Second question: what is easiest way for wiring? I have all the Focus wires and control units. Can I somehow use only engine wiring with ecu? Do I need to delete immo from ECU when I don't use original dash?
Thanks!
Old Feb 22, 2021 | 02:53 PM
big_wasa's Avatar
big_wasa
You can't remove the immobiliser. You don't need the clocks.
It will run happily on a cut down loom.
Your problem will be trying to integrate the ecu to your gems unless you run it fully stand alone.
Old Feb 22, 2021 | 02:55 PM
big_wasa's Avatar
big_wasa
Old Feb 23, 2021 | 04:43 PM
Kristjankae
Thanks for the answers!
Does anybody have wiring diagrams for Focus ST170?
Old Feb 24, 2021 | 08:40 AM
big_wasa's Avatar
big_wasa
Engine or full car ?
Old Feb 24, 2021 | 08:45 AM
Kristjankae
Everything that comes out of ECU would be good.
BlakeMorrisMotorsport
May 18, 2017 01:02 PM
May 18, 2017 12:18 PM
wilba83
Mar 6, 2011 06:33 PM
Shonky
Apr 26, 2009 05:06 PM
GaryHurn
Jul 24, 2008 06:33 PM
