Mk 1 Cosworth seals
Old 21-11-2020 | 04:29 PM
Basco's Avatar
Basco
Default Mk 1 Cosworth seals
Hi every body
I know this has been on the forum before but
can anyone help with this problem mk1 cosworth
changed the camshaft oil seals (VITON )twice now but still leaking only after 5 miles in each case
many body else had this problem
or any other seals I can try
new spacers all bought from BP CENTRE
any thoughts would be grateful
thanks
Old 21-11-2020 | 06:35 PM
cossie2's Avatar
cossie2
......use some gasket sealant ...it helps.
Old 29-01-2021 | 09:35 PM
stevieturbo's Avatar
stevieturbo
C**t
Originally Posted by rowseywile
I have a friend looking to swap a factory turbo into his 2004 Focus wagon, and I got to wondering. How come you see so many JDM swaps for Honda/Nissan/Toyota, but nothing from Europe?
Instead of asking in a thread that has zero relevance to your question.....why not start a new post ?
And google...there are swaps. Here is a recent one that popped up
https://engineswapdepot.com/?p=37144
Old 25-02-2021 | 12:03 AM
kiwikermit's Avatar
kiwikermit
I have the same issue. I replaced the spacers too. No improvement. I'd love to k ow a permanent fix as I had a friend have the same issue too.
Old 26-02-2021 | 07:57 PM
Basco's Avatar
Basco
Default Seals
Hi
first I bought some ELRING OIL SEALS these are like the OEM ones
then I found that the new o seals that go round the bearing retainer were slightly bigger so I used the originals
the spacers were turned so I ground them on a cylindrical grinder it only took about 0.015mm
off
then i used loctite SI 5910 and put this round the new oil seals left for 24 hours to cure
then re assemble making sure the retainer was tapped right back in place and tightened cam cap bolts
also when tightening I pushed the retainer down as I went through the other cam caps this helps to keep the o seal go in evenly you could use the front caps for this
then once all is down take the front two caps off and put the same sealant under them
I all so used a socket and the camshaft bolt to hold the retainer in place
hope this all make sense
sierra1off
266
23-01-2020 09:58 AM
graham c
17-09-2006 06:01 PM
timandnic
28-08-2006 01:37 PM
RST Ski
05-08-2006 01:16 PM
