Ford focus 2014 ecoboost
Old Dec 9, 2020 | 05:01 PM
Ian Mccall's Avatar
Ian Mccall
Default Ford focus 2014 ecoboost
Hi all
I've got a ford focus 2014, 1.0 ecoboost, coming up with fault p0303 misfire detected running rough changed coil pack, plug still same even swapped coil packs and plugs, still with fault p0303p but have notice under acceleration I can only describe as a knock, I'm thinking along lines of an injector?? Anybody got any thoughts
Old Dec 9, 2020 | 05:39 PM
Have you tried googling the fault code??
Old Dec 9, 2020 | 07:45 PM
GVK.'s Avatar
GVK.
303 is cylinder 3 misfire, can be caused by an injector if plugs and coils have been changed/substitutted.
  • Or worse case a base engine fault (piston failure)
Mark_
May 25, 2016 01:29 PM
Dan_L
Ford Focus (All Models)
Jul 1, 2013 09:11 AM
johnblackfocus
May 12, 2013 01:31 PM
Dibley
16
Jan 18, 2010 12:05 PM
cosrep
Ford Focus RS
Feb 28, 2008 09:13 AM
