ford focus will not tick over
12-01-2010, 07:45 PM
focus 1.6 petrol had coil pack n plugs for it misfiring but now it will not tick over , any suggestions
12-01-2010, 07:49 PM
SHITE!
plugs in right order? every thing back as it should be yeah?
12-01-2010, 07:55 PM
2nd that but i think you mean the HT leads
12-01-2010, 08:28 PM
yes ht leads in order no sign of damage to them. drives spot on, no light on dash HELP
12-01-2010, 08:32 PM
right can you start from the start please wot went rong to start with
12-01-2010, 08:47 PM
focus had misfire running lumpy so had coil pack and plug. now its driving ok but when at the lights or junctions car will not tick over with out having a bit of thottle on ?
12-01-2010, 09:51 PM
Are the plugs in ok, sounds as if an air leak may have been introduced.
Martin
12-01-2010, 10:07 PM
competant bodger
is it the plastic manifold zetec? these are prone for cracking usuaslly have to remove manifold to see crack they give the symptoms your having
13-01-2010, 07:04 AM
Idle control valve maybe? They are quite a common failiure on the focus. Could just be coincidence that they've failed at the same time?
13-01-2010, 07:05 AM
Maybe coincedence, but these suffer with speedo sensor faults which cause
them to stall at junctions, keep an eye on the speedo to see if it stops
working when it stalls.
puddy
13-01-2010, 07:20 AM
Quote:
Originally Posted by
puddy
puddy
Thought that only happened on the 1.8/2.0 Focus?
As said above Idle Control Valve would be the thing i would be looking at next, either clean it or replace it.
13-01-2010, 07:34 AM
Ford for life
wirralphil
nope, every model except tdci iirc, it deffo happens to 1.6 ,my sisters is on its 3rd, thats a 16
13-01-2010, 08:42 AM
It is most likely just something disturbed if it's only just started doing it, maybe a broken pipe on PCV system("T" piece), or sometimes the pcv valves themselves jam open so it leans it all the time, the valve should shut at idle.
Would not hurt to clean the iscv though, and reset the ecu by pulling the KAM fuse for a minute, 2 amp violet one.
13-01-2010, 08:46 AM
mine ran reallt bad after changing coil pack for same problem reseting ecu sorted it dunno why just unplugged battery for half hour
13-01-2010, 10:29 AM
mozzy
You learn somthing every day.
Does this happen on Fiesta Zetec S MK5?
13-01-2010, 10:57 AM
also at manifold front of engine, you can just get through theres vacum hoses these are famous for leaking, try spraying a bit carb cleaner about when engine running to see if can here it sucking it in anywere
18-01-2010, 12:05 PM
thanks people now sorted tured out to be vacum pipes now running as it should.
Ford Focus RS Parts for Sale.
18-08-2015 05:25 PM
taylora1409
12-08-2015 12:06 PM
16 ,
18 ,
car ,
compensator ,
fiesta ,
focus ,
ford ,
lumpy ,
o4 ,
poor ,
tick ,
ticking ,
tickover ,
wont ,
zetec
