Fiesta mk2
Old Oct 4, 2020 | 05:32 PM
Rogue 1's Avatar
Rogue 1
Default Fiesta mk2
Hi I am looking for some advice / technical help with my MK2 fiesta
the car starts & runs fine, but cannot get car to move , clutch pedal seems fine , not to high or not to low , feels as normal as a clutch could be position etc, clutch arm on top of box seems to move ok , but can put car in gear , and let clutch out and nothing there , normally a car would stall or move etc , but nothing evident so far , gear selecter rod seems to move freely underneath, getting mad with it now just want to get it working & driving any help greatly appreciated
Old Oct 4, 2020 | 05:47 PM
gcfcos's Avatar
gcfcos
Sounds like clutch has gone to me mate
Old Oct 8, 2020 | 08:25 PM
martysmartie's Avatar
martysmartie
With it in gear and engine off, can you push it?
Martin
Old Oct 8, 2020 | 10:53 PM
Rogue 1's Avatar
Rogue 1
Default Gears
Martin
hi Martin can push it in gear ⚙️ while gear is selected in car
Old Oct 10, 2020 | 10:34 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
very much points to a knackered clutch
Old Oct 10, 2020 | 10:47 PM
COLEYST200's Avatar
COLEYST200
Did you get the car like this or has it suddenly gone like it
Old Oct 14, 2020 | 12:52 PM
martysmartie
So the fact it moves in gear would suggest the transmission is disengaged from the engine and the component that does that is the clutch.
However, if it were worn, it would slip, but you would still be able to move it.
Looks like the box needs to be removed to inspect the assembly.
Martin
Rogue 1
Sep 28, 2020 05:49 PM
djchurch2001
Mar 25, 2012 08:45 PM
loveland
Sep 18, 2011 08:11 PM
big hyndy
Ford Focus RS
Jun 29, 2011 04:20 PM
dojj
32
Nov 30, 2009 01:54 PM
