St 170 maybe old hat
Old Aug 29, 2020 | 01:26 AM
Bikeratheart's Avatar
Bikeratheart
Default St 170 maybe old hat
I'm new to all this forum stuff,
I'm sure these questions have been asked before, have an st 170, spluttering when its been in traffic and dieing when coming to a stop, battery lights comes on too? The alternator is charging, but only 13.6? But the car also starts every time, normally to my knowledge once the car is running a failing alternator shouldn't kill the car?? Or am i wrong, any help would be great.
Old Aug 29, 2020 | 07:38 AM
Welcome to PF.
So when you say sluttering in traffic, is it when the car is idling? Or does it splutter after you have been in traffic then your pulling away??
I know its a different car but I had a problem with my cossie once,it would be fine say doing 50 60mph then when I got into traffic and the car sat for a while before pulling off the cossie would splutter/misfire cause the engine had got warmer. I fitted a water temp sensor which cured this fault.
Old Aug 29, 2020 | 07:44 AM
Bikeratheart
Hi there
It's as you pull away at low revs,
Almost feels like over fueling? Temperatures seem good.
Old Aug 29, 2020 | 08:32 AM
Well the temperature sensor might be telling the ecu the wrong reading and thinking the engine is cold so its putting more fuel in the engine causing the splutter/misfire... its worth a try. If you had a good diagnosis tester you could have a look at the water temp sensor reading.
Old Aug 29, 2020 | 08:34 AM
I used to own a ST170 myself a few years back was a decent car. Mine had both custom and climate pack. I bought it for 600 and sold it for 900.
Old Aug 31, 2020 | 01:10 PM
STeve's Avatar
Super Moderator
sadly the st170 is a car that does not age well broke 100s of them over the years and many examples I see not on the road are on limited time
Old Aug 31, 2020 | 03:07 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Is it mainly rust that is killing them?
Future classic. For me, Imperial Blue 3dr, original wheels with no center caps, Recaros, Xenons, boot spoiler & 9006 headunit with sub.
Old Aug 31, 2020 | 05:40 PM
STeve's Avatar
Super Moderator
not so much rust although being a ford its never far away, steering racks and vvt pulleys seam to pop up all the time now, plus as they wasa cheap car for so long so many are chavved up very tired examples beyond economical saving
Old Aug 31, 2020 | 08:31 PM
I defo think they will be a future classic. Ive seen a few sell on ebay for 2k upwards.
Dodgewc62
Ford Focus ST
Feb 9, 2020 08:51 AM
Big G
16
Jul 2, 2009 05:28 AM
KW-rscos
52
Dec 14, 2006 09:14 PM
Demon
Feb 19, 2006 06:13 PM
