Possible Fuel Pump not working....
Old Jul 19, 2020 | 02:11 PM
91FiestaRST's Avatar
91FiestaRST
Default Possible Fuel Pump not working....
I have a 91 Fiesta RS Turbo drove it about 7 miles, stopped and went to start it again and now it wont fire up. At first it wanted to but now...nothing.
Checked the fuel pump relay doesn't seem to be burnt out and the wiring seems to be fine , also seems to be earthed correct. I haven't tested to see if there is power to the pump. to be honest i'm unsure how to..
Is it worth changing over the fuel pump relay? if so where can i get one?!
Just to confirm is it the middle yellow relay?
Cheers in advance
Old Jul 19, 2020 | 06:56 PM
GVK.'s Avatar
GVK.
Don't know which relay it is but you can bridge the 2 largest terminals in the relay socket with a bit of wire and see if the pump runs]
I have bumped an old thread about this. https://passionford.com/forum/genera...t-priming.html
Old Jul 25, 2020 | 04:35 AM
paulee's Avatar
paulee
Put 1 of the fuel lines in a bottle and turn it over.
Old Jul 25, 2020 | 04:41 AM
BillyEdmonds's Avatar
BillyEdmonds
Give the fuel tank a "tap" with a rubber mallet while cranking the engine. If it fires, replace the pump.
LEE-RS
Jan 3, 2021 08:48 PM
smerth54
Dec 18, 2008 12:28 AM
OLDSKOOLRYAN
Oct 22, 2007 10:57 AM
dalsy70
Ford Escort RS Cosworth
17
Oct 3, 2007 09:33 PM
andre_k
Jan 12, 2006 02:36 PM
