Gearbox for cosworth YB Turbo
Old Jul 19, 2020 | 07:50 AM
Mattus1000's Avatar
Mattus1000
Default Gearbox for cosworth YB Turbo
Hi all! Looking for some help/opinions.
I have a T5 box mated to my cosworth YB turbo but have had to rebuild it numerous times as the syncros keep failing resulting in mainly not being able to select third gear. I am not sure why this keeps happening as running just under 300bhp, but it could be due to the exhaust crossing under the gearbox and overheating it.
Can anyone recommend a different box that might be more reliable? Or, does anyone know if I can get improved internals for the t5 so it stops happening?
All help appreciated!
Thanks
Matt
Old Jul 19, 2020 | 06:44 PM
pectelboy's Avatar
pectelboy
You can get I big tooth internals , quaife also do a t5 kit
Old Jul 19, 2020 | 09:06 PM
Mattus1000's Avatar
Mattus1000
thanks, will this solve the syncro issue do you think?
Old Jul 19, 2020 | 09:40 PM
Adam-M's Avatar
Adam-M
I’d watch a few videos from Paul before building it sounds like something is else is faulty
Old Jul 19, 2020 | 09:47 PM
scoooby slayer's Avatar
scoooby slayer
At upto stage 3 I had very little gearbox trouble 350 hp 2wds, I had one 3rd gear synchros issue but the box was just very old and tired once rebuilt by A1 gearboxes was never any bother again
Seems strange it keeps going makes me think there's a 3rd gear issue that's not getting properly resolved in the rebuilds
Old Jul 19, 2020 | 09:54 PM
Adam-M's Avatar
Adam-M
Paul the t5 specialist goes through problems with brand new synchros, all the new replacement parts are made by tremec who bought over borg Warner transmissions and it seems they make poor quality parts and allot of prep work needs done to new components before fitting them. New synchros can be too tight on the hub and need a light rub with emery ect and some even have burrs and dents
Old Jul 20, 2020 | 09:42 AM
Mattus1000's Avatar
Mattus1000
Thanks all for your help, really appreciated!
Thinking of sending it to CTS for rebuild unless anyone thinks that is a bad idea?
Old Jul 20, 2020 | 03:45 PM
pectelboy's Avatar
pectelboy
They did mine 400+ bhp in a escort mk2 without any problem
Old Jul 20, 2020 | 06:07 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I had a cts big tooth box was great I couldn’t fault it
Old Jul 20, 2020 | 09:37 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
CTS did mine. Standard spec with good quality bearings. Doing it again I would pay the extra and go big tooth conversion as above.
Old Jul 20, 2020 | 09:54 PM
turnover's Avatar
turnover
Tbh a stock t5 should be ample for that power ,also depends what oil your using ,and also clutch,if your trying to do fast gear change from 2nd to 3rd maybe the clutch isn’t clearing quick enough,would have it stripped and inspected first
Old Jul 22, 2020 | 04:59 PM
stevieturbo's Avatar
stevieturbo
C**t
No.
If you are wrecking synchros, it's either clutch related, or driver related.
Old Jul 22, 2020 | 05:10 PM
Mattus1000's Avatar
Mattus1000
Originally Posted by stevieturbo
No.
Thanks for this mate. The clutch is an AP 6 paddle but is quite old now so could be that. Is there anything you would suggest that could help?
If its driver related, what can I do to change?
Thanks
Old Jul 22, 2020 | 05:22 PM
stevieturbo
C**t
Age of clutch is irrelevant.
If the clutch is not releasing properly, it will be hard on synchros.
If the driver isn't using the clutch properly, or trying to ram gears too fast...it will be hard on the synchros.
Basically anything that is keeping the input shaft spinning when the clutch should be disengaged..will cause it to be hard on synchros.
Of course the other possibility is totally wrong oil.
Old Jul 22, 2020 | 07:06 PM
Mattus1000's Avatar
Mattus1000
Just running mobil atf220
Max-Dax
Dec 14, 2014 08:38 PM
killa_paul
Sep 13, 2011 05:09 PM
Icekottarinn
Technical essay Archives
Feb 17, 2011 10:28 AM
brizer
Dec 13, 2009 04:33 PM
Lewis-Zetec-S
May 14, 2006 08:03 PM
