Picture of YB? T5 fits Cosworth/Pinto-more?
Can anyone insert a picture of the Cosworth engine showing the side where the bell housing bolts on? The "Rear side/Clutch" of the YB engine - when the gearbox has been removed!
Which engines does the T5 gearbox fit others then the YB/Cosworth/Pinto?
Thanks!
Thanks!
3dr Cosworth owner
Whats a henway?
Yes, the T5 from a 5.0L Mustang can be used with the bellhousing from T5 2.3L OHC 4 cylinder to fit the Pinto 205 block.
There are a few differences, the input shaft will need machining to fit into the pilot(spigot?) bearing, plus the alignment dowels
are different as well. I'll have to run out to the shed and see what's different, as I can't think of it right now...
www.rallyanarchy.com
The ears sticking out from the case are different, but at least the shifter on the GM box is in the same place as a Cossie one---and not 3 or 4" foward like Ford USA V8 boxes (which also have a shorter first gear---3.36 vs Cossie and GM 2,95)
One could mix and match a GM gearset in a Ford case which would direct bolt to the Cossie bellhousing, then use the GM tailshaft housing and shjift shaft stuff...
GM spines on input and output are, of course, different.
But then again so is US Ford from Euro Ford.
steerfromdarear
28
29-01-2016 06:14 PM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
