Ib5 Rear starter fitment to CVH
Old Jul 17, 2020 | 07:54 AM
Mika Komulainen's Avatar
Mika Komulainen
Default Ib5 Rear starter fitment to CVH
Have enyone tried? I bought rear starter ib5 to replace my old bc box because bearings. Starter hits the oil filter but have heard there's way out of it ?
Old Jul 17, 2020 | 07:59 AM
haz87's Avatar
haz87
Smaller starter should do the trick. Transit connect may well be small enough and meshes fine with the CVH flywheel (i used one albeit front mounted)
Old Jul 17, 2020 | 10:03 AM
XR2's Avatar
XR2
People keep saying it "should" work. But I've never seen any proof yet.
When Ford started to use the rear starter boxes, the 1.4 PTE (CVH successor) still were fitted with front starter boxes. When there's no big issue fitting rear starter boxes to the CVH engine then why did Ford only use these boxes on the Zetec-E and Zetec-S engines?
Old Jul 20, 2020 | 06:33 PM
Mika Komulainen
Yes bought the back starter box and the gap between filter and starter mount is maybe 30-40 millimeters ? Some engineering before you get it there. Also had to chop one gearbox mount bracket from cvh block. It lined up straight to the ib5 starter mount hole.
Old Jul 20, 2020 | 07:25 PM
XR2's Avatar
XR2
Pics?
Old Jul 21, 2020 | 12:33 PM
Mika Komulainen
Here the gap from fitment plate to filter
Different view
Old Jul 21, 2020 | 12:46 PM
Mika Komulainen
Old Jul 21, 2020 | 02:40 PM
XR2's Avatar
XR2
Oh dear.
Old Jul 21, 2020 | 03:16 PM
Mika Komulainen
Maybe i just find front starter version
Old Jul 21, 2020 | 03:58 PM
Mika Komulainen
Dunno if the transit starter is less than 70 millimeters from the mounting surface ?
Old Jul 22, 2020 | 05:05 AM
haz87's Avatar
haz87
Yer the Transit starter isnt fitting in there - didn't realise it was that tight. No idea how people have got round this
Old Jul 22, 2020 | 07:18 AM
XR2's Avatar
XR2
They probably didn't. The breather pipe stands in the way and even when you use an oil filter relocation kit there's not enough space for any starter motor.
They all probably had early Zetec engines, no big issue using rear starter boxes with these engines.
Old Oct 2, 2020 | 09:27 PM
Mika Komulainen
Old Oct 13, 2020 | 11:46 PM
Mika Komulainen
Old Oct 14, 2020 | 05:05 AM
haz87's Avatar
haz87
Did that get pulled out of a tar pit?:O
Old Oct 15, 2020 | 03:54 PM
Mika Komulainen
Probably yes, box is in. Tomorrow modification of the clutch fork, wonder how that bigger flat release bearing works :OO
Orion_Gav
Mar 15, 2016 03:50 PM
GINGExR2 T
Mar 13, 2013 10:22 PM
wedge07
Sep 6, 2012 08:48 PM
fiestaturbo1984
Sep 17, 2006 01:44 PM
mr_klm
Feb 18, 2006 09:34 PM
