3 soor cosworth timing
Old Jul 5, 2020 | 08:27 AM
HGjohnson's Avatar
HGjohnson
Question 3 soor cosworth timing
Hi a friend of mine has had a timing belt done on a 3 door, the engine now sounds like its got a rattle on the tappets any suggestions?
The engine didn't rattle before belt change! any help / advice would be great
thanks
Old Jul 5, 2020 | 10:37 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
My advice. Don't drive it! Get someone else who knows how, to re-check timing. Tapping after belt change does not sound good and imo only comes from piston/valve contact.
disclaimer - i am not a mechanic.
Old Jul 5, 2020 | 09:19 PM
christos's Avatar
christos
10 Year Member
DONT START ENGINE!!!!
Like above,something is wrong with timing. Get an experienced person to check cam timing.
Old Jul 13, 2020 | 04:36 AM
The Youth.'s Avatar
The Youth.
There was a very common mistake back in the day to time a yb up on the bottom pulley timing marks, that is wrong it must be on the first peg after
very good chance this has happened
steve
Old Jul 13, 2020 | 04:36 PM
martysmartie's Avatar
martysmartie
steve
Been there done that, I was like 21 at the time and tried to do it on a holiday camp, I did not have a clue what I was doing back then
As said, there is a notch before TDC, which indicates 16 BTDC (the ignition timing) hence NOT TDC!
As said, the timing is defiantly wrong, you only have to be a tooth out.
Do not start it again and check the timing, there is no excuse for a professional mechanic getting this wrong though!
At TDC, the rotor arm should be at 2 o'clock facing the scribe in the dizzy, the cam pulley arrows facing each other and the cam pulley lug should meet the metal on the block. There is also a half moon on the aux pulley.
Martin
gunmetalgrey
Ford Focus ST
11
Jun 30, 2011 12:32 PM
mackers
Mar 29, 2009 06:35 PM
ickey818
Dec 14, 2008 09:33 AM
OrionRST200bhp
Jun 3, 2007 10:27 AM
J9BBY
Jun 23, 2006 09:03 AM
