1990 Cosworth 4x4 - Rubber Doughnut
Old Jun 28, 2020 | 06:04 AM
Mattivenn's Avatar
Mattivenn
Default 1990 Cosworth 4x4 - Rubber Doughnut
Hi All,
I'm currently having my 1990 Sapphire Cosworth 4x4 gearbox rebuilt and have discovered the rubber doughnut is knackered. Its the early, thicker type.
I've done a bit of digging and, as usual, the part hasn't been available for some time. The only solution to enable a new, thinner, later type doughnut (1992 onwards - and readily available) to be installed is to swap the output flange and maybe a couple of other things including the front section of prop shaft also from the later Sapphire Cosworth/Escort Cosworth.
Is there anyone out there that has acutally done this mod and can tell me EXACTLY what I need to get and do to make sure this works?
Had lots of people give opinions but nothing solid. Any advice/guidance would be gratefully received.
Alternatively, if anyone knows of a solution/alternative part to replacement, that'd be awesome.
Many thanks.
Old Jun 28, 2020 | 11:05 AM
smiley's Avatar
smiley
I'm sure you will get a response for this as I remember it's been mentioned befor mate
Old Jun 28, 2020 | 12:02 PM
cossie2's Avatar
cossie2
..I got mine from Burton
Old Jun 29, 2020 | 06:29 PM
Caddyshack's Avatar
Caddyshack
I got one for a 4x4 from Burtons.
Old Jan 11, 2024 | 08:56 PM
Speedfreak999's Avatar
Speedfreak999
Default Ruber donut replacement
Originally Posted by Mattivenn
Hi All,
Many thanks.
E rubber can remanufacture your old one all you have to do is post it to Greece get rapped by customs 🤣🤣🤣 these people are great to deal with and do a top job costs around £350 once the import charges have been paid but we'll worthy if you want to keep your car standard. Hope this helps.
RetroTed
18
Apr 19, 2016 11:28 AM
155lee
Dec 29, 2010 10:09 PM
cala
Jun 21, 2008 12:13 AM
