Scotland This is where members fromScotland can arrange their meets and chat together.
Handbrake issues
Old Jun 3, 2020 | 08:28 PM
Bigkevg's Avatar
Bigkevg
5 Year Member
Default Handbrake issues
Hi folks
build my mk4 rest bleed the brakes non abs. Got brakes working on the pedal. Just can’t get handbrake to work. Adjusted it right up, no luck, opened up hubs maxed out adjusters on fully adjusted cable still no handbrake.
Do I need a non abs handbrake as got non abs brake shoes, I am stumped. I have had an XR3i For 20 years and hand brake and brakes were always easy to sort out.
A point in the right direction would be decent
Kev
Old Jun 3, 2020 | 09:16 PM
martysmartie's Avatar
martysmartie
Not been involved with these, but I believe the handbrake cable will have an adjuster on it, could this be the issue?
I don’t think the ABS makes any difference.
Martin
Old Jun 3, 2020 | 09:26 PM
Bigkevg's Avatar
Bigkevg
5 Year Member
Martin
Cheers Martin
I have turned the adjuster On cable fully up, also shifted adjusters in brake drum fully up.
it has puzzled me. Maybe need to call burton power regards abs and non abs handbrake cables ,shoes etc
Old Jun 5, 2020 | 08:09 AM
tmorris2009's Avatar
tmorris2009
Originally Posted by Bigkevg
Hi folks
Kev
you might have wrong handbrake cable, I'm doing up a mk4 xr3i at the moment, when buying new handbrake cable there was different options, ABS or non ABS, so there must be a difference in the cables
Old Jun 5, 2020 | 10:49 AM
Bigkevg's Avatar
Bigkevg
5 Year Member
Hi Morris
A called Burton power today and it’s the hand brake cable.
10cm of a difference from non abs to abs cable. Mad
cheers tho. Kev
Old Jun 5, 2020 | 11:00 AM
tmorris2009
Hi Morris
cheers tho. Kev
no worries mate, glad you've found the issue
Old Jun 5, 2020 | 11:07 AM
Bigkevg's Avatar
Bigkevg
5 Year Member
By the way I have few XR3i bit
turbotrev
Apr 17, 2016 08:35 PM
wedge07
Apr 5, 2012 08:15 PM
mikelomax
Nov 2, 2009 06:55 PM
LINCOLN
16
Mar 30, 2008 11:35 AM
C14KEE
May 23, 2006 05:59 PM
