ABS and big brakes
ABS and big brakes
Starting from scratch on a track car.
I am installing a pedal box with 6 pots/356 and 4 pots/330 brakes.
Would you retain the standard 3 door ABS?
Or ditch it all and start brake lines again?
I ask this because modern abs and big brakes sometimes does not work with ABS working too early - I am told that similar cars with different brake sizes have different ABS cals from the factory.
A mates car with big brakes does ABS too early.
Resident Wrestling Legend
keep what you have for the moment
if you feel that oyu need the adjustability then fit a bias knob in the rear line
the abs kicks in early because you have that mush more stopping ability
if you want to start from scratch then your line about keeping the bas and fitting a pedal box means you don'tknow what you are doing, so leave it to someone who does or get proper advice
not teaching you to suck eggs, just making the point before osmeone else does
Not sure I talked about a bias?
THe pedal box will adjust bias front to rear - I have not looked at the ABS module but I suspect that it is either a two or four port module (as it has a sensor each wheel - it would definately not be diagonal spilt).
Therefore I could have my pedal box still adjust bias and retain proper ABS functionality.
Am I wrong?
Am I wrong?
Guest
Posts: n/a
take it from my experience :
ford abs and big brake kits dont go well together...this for the 1st......
now the bias box is useless if the abs then changes brake pressure depending on lockup factor.... u can set whatever u want, abs will change it again......
so.....bias and NO ABS.....or std. box and ABS (with std calipers, rotors, etc)
Am I right about Bias knobs only being flow reducers not pressure reducers? Because it is was a pressure reducer it could not be plumbed inline without needing a bleed port. Or if it was an unequal size piston type (commonly used in hydraulics) which can be plumbed in line then it is not adjustable?
Has anyone got ABS to work with big brakes?
