Sapphire sunroof removal
Old May 31, 2020 | 06:00 PM
Beanzntoast's Avatar
Beanzntoast
Default Sapphire sunroof removal
Hi all,
Could somebody clearly tell me how to remove the sunroof & rails as theres no chance of just removing the glass/frame on its own due to rust.
I dont want to just take all the screws off when the sunroofs fully wound back as theres 5 down each side & 6 across the front so was abit worried of the cable coming out of its runners if i took the wrong ones out
Many thanks in advance
Old Jun 1, 2020 | 11:57 AM
martysmartie's Avatar
martysmartie
Originally Posted by Beanzntoast
Hi all,
You don't need to remove all of them, however if your roof open's to me seems it's not that bad.
There are two at the front, which screw into 'u' nuts for the handle surround inside and a few more.
Start from the front as all of them have to be removed and once it starts lifting it's obvious what ones you don't need to remove, I think it's like two or something midway down the frame at either side.
There are six screws which secure the roof itself, I guess you can't remove these?
Martin
ajamesc
21
Jun 23, 2025 03:13 AM
saph in dorset
Feb 10, 2015 09:26 PM
killa_paul
Jun 27, 2012 02:10 AM
killa_paul
Mar 15, 2012 08:00 PM
