help
Old May 8, 2020 | 06:44 PM
tommyrs's Avatar
tommyrs
Default help
any of the old school people out there know how to setup an rs turbo with efi cant get the mixture and idle right
Old May 9, 2020 | 09:47 AM
martysmartie's Avatar
martysmartie
You need to describe the management/setup you have, given it's not standard.
Martin
Old May 9, 2020 | 10:46 AM
tommyrs's Avatar
tommyrs
thanks for the reply the car was converted to efi done by oddkidd i was told its running i8 cossie management
Old May 12, 2020 | 06:56 PM
martysmartie
Ok, so providing it's mapped correctly, the only thing you can do is adjust the CO pot (i.e.a screw on the ECU) assuming you are not running closed loop.
The thing is yours will probably have had a live map, given there are no off the shelf calibrations for the CVH, as it's not the standard management.
This means you don't know what the CO value should be, only whomever mapped it will.
Be aware, there may be an underlying fault(s) causing this ranging from an air leak to sensor issue.
Martin
Old May 12, 2020 | 07:31 PM
tommyrs's Avatar
tommyrs
it was live mapped ive asked jano oddkidd who did the map for the co value
any pointers on what to check and where to start for a newbe like me
Thanks
Tommy
Old May 30, 2020 | 12:44 PM
tommyrs's Avatar
tommyrs
i was checking the sensors and read that tps should go up from 0volts to 5volts on the l8 ecu i was told i have a l8 but my tps starts at 5 volts and goes down to 0 throttle full open ?? dose this mean i really have a l6 as when i looked at the inside it looks like the l8 with small extra board can anyone tell me if there another way to identify which i have
Old Jun 1, 2020 | 12:06 PM
martysmartie
It's the polarity, not the TPS, nor ECU
You are correct in your understanding of the operation, which IF you have an L8 (most likely) means someone has likely used a 2WD loom (so the outer wires on the TPS need inverting) or just fitted it wrong, period.
There are two TPS's, PF01 and PF09, the latter was used on the 4x4 (L8) and BT Escos.
The easiest way to determine which one you have (in lieu of being able to look at it) is to do a continuity test, PF01 is open circuit at idle, 09 won't be.
Martin
Old Jun 1, 2020 | 01:41 PM
tommyrs's Avatar
tommyrs
thanks martin
but i want to know which ecu it is as then can check if the tps is the right one or if there has been a 2wd loom used is there a sure way of testing or could i send you photos as the ecu is in a l6 case as seen on the website bigturbo.co.uk so a little lost
cheers
Tommy
Old Jun 1, 2020 | 02:07 PM
tommyrs's Avatar
tommyrs
heres some photos of the inside of the ecu
Old Jun 1, 2020 | 04:21 PM
martysmartie
That's an L6, with a Pectel board.
Martin
Old Jun 1, 2020 | 05:39 PM
tommyrs's Avatar
tommyrs
thanks for squaring that up for i was told when i bought the car it was an l8 🤬 so that means i cant get a new tps anyone got an pf01 laying around
have read the pf09 will work but does work as good (with wires swopped )
as mine goes from 4.88 volts (closed) to 0.35to (open) but there is jump so not smoth everytime this i think means mine is on its way out
Old Jun 2, 2020 | 12:11 PM
martysmartie
What makes you think the TPS is the issue?
Not really, although it will run, idle strategies etc will not operate.
Martin
Old Jun 2, 2020 | 02:32 PM
tommyrs's Avatar
tommyrs
mine works but theres is a jump in volts somtimes so not sure if its 100% good gonna check all the other sensers this week but as you confirmed mine is a l6 will try and find a pf01 to be sure as hard to get hold of now since they dont make them anymore
Old Jun 3, 2020 | 06:02 PM
martysmartie
I doubt it, easiest way to check is to plug it and see if the idle is improved.
The calibration can be adjusted.
Martin
Old Jun 8, 2020 | 03:00 PM
tommyrs's Avatar
tommyrs
well was busy this weekend looking for air leaks as tested all sensors and thought a new throttle gasket was a good start and when i took it off seen that i have a pf09 pts 😡
could this be the cause of my bad idle ??
i think so
so got a 2nd hand pf01 ebay now wait and fit when it comes
Old Jun 9, 2020 | 11:26 AM
martysmartie
i think so
It will yes, the PF01 is different as it contains a switch, which is open circuit at idle.
The ECU looks for this signal to activate it's idle/overrun strategies.
Hence why I said, unplugging it would determine the idle improvement.
Martin
Old Jun 12, 2020 | 07:33 PM
tommyrs's Avatar
tommyrs
well put on the new pf01 and it was good didnt have to change wires 🤔
it was already showing 4.8 at idle and went down to 0.4 full throtle but now seems to hold back a little now i am confused 🤪
is there somthing i am missing here as its more steady now low revs but seems slower
carlo
Jul 23, 2015 11:39 PM
G2RSR
Oct 7, 2012 11:40 AM
