RST Problem - No fuel
Old Apr 14, 2005 | 04:52 PM
Jim Galbally's Avatar
Jim Galbally
Default RST Problem - No fuel
OK posting for lennie as he's just put an RST back together and there's no fuel coming thru
fuel comes out of cold start fine, but notihng to the std 4 injectors
is this DEFINATELY a mechanical problem? or could it be electronics related?
deffo fuel going into metering unit, but nothing coming out of the injctor holes.
Old Apr 14, 2005 | 05:19 PM
Rick's Avatar
Rick
have u tried cranking it, and depressing the meterign flap while doing so?
B19LRW's Avatar
B19LRW
Its Broken.....
top,as jim says i have tried 3 metering units now..(not known if good or not) and have jsut got one to try tomoorow. car was running fine, was stripped and im refitting. could it be the loom/electrics ( the loom is in vgc)
Old Apr 14, 2005 | 05:20 PM
B19LRW's Avatar
B19LRW
Its Broken.....
yes mate, no fuel whatsoever!(only at coldstart )
Old Apr 14, 2005 | 05:28 PM
B19LRW's Avatar
B19LRW
Its Broken.....
help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 14, 2005 | 05:32 PM
Rick's Avatar
Rick
if u disconnect the multiplug at fuel pressure reg, this will eliminate electrics. Have u tried checking for fuel at injector feed on metering head?
Old Apr 14, 2005 | 05:33 PM
Westy's Avatar
Westy
would say its unlikely to be that then... whats the chances of 3 faulty ones..??
Old Apr 14, 2005 | 05:40 PM
Rick's Avatar
Rick
maybe get someone to post u another?
Old Apr 14, 2005 | 05:41 PM
Manchester Mike's Avatar
Manchester Mike
Think i have a spare...
Old Apr 14, 2005 | 05:42 PM
xr4x4rs's Avatar
xr4x4rs
metering head mate
i know u have changed 3 now by whats said
but if there left around not working they tend to sieze up
Old Apr 14, 2005 | 05:44 PM
Rick's Avatar
Rick
dont think u'll be able to send the whole thing at once - maybe in 2 parts?
Old Apr 14, 2005 | 05:45 PM
Manchester Mike
hit it with a hammer
Old Apr 14, 2005 | 05:47 PM
Manchester Mike
Yeah, could split it then post seperatly, and in seperate years
B19LRW's Avatar
B19LRW
Its Broken.....
tried that mate, and hit it with a hammer!!
Old Apr 14, 2005 | 05:50 PM
Manchester Mike
Hit it harder
Old Apr 14, 2005 | 05:55 PM
david's Avatar
david
Try taking the plugs out and main HT lead off, get someone to hold the paddle down in the metering head whilst you crank the car over. It is normally just an airlock that needs bled out. Once you can smell petrol in the bores let it dry off a bit and then re-fit plugs and HT lead.
Old Apr 14, 2005 | 05:57 PM
B19LRW's Avatar
B19LRW
Its Broken.....
airlock?? will try that!
Old Apr 14, 2005 | 05:58 PM
david's Avatar
david
Yeah its common if youve had any fuel lines or the metering head off
Old Apr 14, 2005 | 06:08 PM
Manchester Mike
Undo the enjection pipes from the metering head, u should get petrol pissing out, if not work back, undo pipe off fuel filter etc.. at each point turn engine over to see if petrol is pumping through ( take the plugs out tho as compressing the bores will drine the battery quicker. sounds silly but is the pump/relay workin? most prob just an air lock though.
Old Apr 14, 2005 | 06:09 PM
Manchester Mike
Don't know what i've just done
Old Apr 14, 2005 | 06:23 PM
B19LRW's Avatar
B19LRW
Its Broken.....
sorted mike... right, have petrol@ m. unit, and NO petrol from injetor unions on unit. does that little black bos on the right near the turret have any power over if fuel gets thru?
Old Apr 14, 2005 | 06:34 PM
Manchester Mike
think thats the pressure regulator
Old Apr 14, 2005 | 07:35 PM
B19LRW's Avatar
B19LRW
Its Broken.....
bttt any more help???
Old Apr 14, 2005 | 08:54 PM
Rick's Avatar
Rick
Lennie, manchester mike has left a voice mail message on your phone with a possible answer
Old Apr 14, 2005 | 10:16 PM
B19LRW's Avatar
B19LRW
Its Broken.....
doh... i deleted it! by accident!!!
Old Apr 15, 2005 | 11:28 AM
B19LRW's Avatar
B19LRW
Its Broken.....
err all sorted now. sort of. it was only pumping a little petrol.. lol
Old Apr 15, 2005 | 11:56 AM
Jim Galbally
eh? what you mean sorted?
Billy_RS
16
Oct 11, 2025 09:41 PM
JK12
33
Apr 26, 2021 12:09 PM
A.t.p
Aug 15, 2015 11:37 AM
Sjieter
Aug 5, 2015 09:47 PM
dlwarrior
Aug 5, 2015 10:19 AM
