Re which electric fuel pump xr2
Old May 2, 2020 | 09:31 AM
wenmoll's Avatar
wenmoll
Default Re which electric fuel pump xr2
I’ve got a 1985 xr2 running the original mechanical fuel pump but I wanted to change it to electric fuel pump and wondered the best way of doing it? I was after some advice on type of pump to get and how to incorporate a shut off in case of an accident.
many thanks in advance
Old May 2, 2020 | 11:20 AM
martysmartie's Avatar
martysmartie
I don't see why you want to change?
I think you need to be mindful of the pressure, which means a regulator would have to be installed.
If it's to high you risk forcing fuel past the needle valve.
Facet seem to be popular, but can't be more specific on on the type, as to the cut off, any inertia switch would be fine, wired in series to the pump supply.
Martin
rob803
Feb 25, 2009 03:41 AM
rob803
Jan 14, 2009 10:22 AM
SaqsS2turbo
17
Apr 25, 2008 04:37 PM
cosworth_wannabee
Apr 17, 2007 12:01 AM
cosworth_wannabee
Apr 16, 2007 11:23 AM
