Xr2 Fuel set up.
Old Feb 24, 2009 | 04:54 PM
rob803's Avatar
rob803
Default Xr2 Fuel set up.
im putting twin 40s on my xr2 do i need to change the fuel pump or will the original mechanical 1 cope?
Old Feb 24, 2009 | 07:05 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
i would put a facet interrupter pump on with a fuel pressure reg hav a look on the demon tweeks web site you can get the fuel pump blanking plates aswell
Old Feb 25, 2009 | 03:41 AM
As said defo uprate fuel pump, you could also use a filter/regulator combined, the pressure is very low on carbs, so make sure the reg goes low enough to suit carbs.
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Aug 30, 2015 08:07 PM
Ben26
Aug 27, 2015 08:56 PM
Steve Escos
Aug 24, 2015 07:56 AM
Perfmr2
Aug 6, 2015 07:30 AM
