Zetec silvertop oil pressure
I have a 1.8 silvertop in my Lotus Europa. The oil pressure drops off when hot.
Smiths electric gauge, swapped sender still same. Pressure switch is a 20psi job and light is flickering.
The engine was a Ford short motor, crank has been ground 0.25mm u/s. Had it stripped and measured, all good. Oil pump and bearings look fine.
what is a normal hot pressure for these? Am I chasing shadows?
cheers
cheers
Hot pressures generally vary between 1.3-2.5bar at idle (18.8-36.2psi)
So if its just under 20PSI thats fine, but just relying on the low pressure switch/light is guesswork really. Whack a gauge on and get a proper idea of the pressure. Could be 5psi for all you know..
Thanks for the reply, that's lower than I expected on a "modern" engine. I could well be chasing shadows.
I've rigged up a mechanical gauge so I can cross check the electric gauge when it's all back together. If that's good I'll look into an adjustable pressure switch for the light.
the pressure rises nicely with revs.
