act guages!! where to mount the temp part???
Old Apr 14, 2005 | 03:10 PM
pau1rs's Avatar
pau1rs
Default act guages!! where to mount the temp part???
got me act guages or a very helpfull mr rainbird!!!!
got the super "twins" holder to fit it in!!!!
but where is best to mount the temp sensor on the car???
cheers all!!!
Old Apr 14, 2005 | 03:11 PM
rsnissan's Avatar
rsnissan
inlet manifold
Old Apr 14, 2005 | 03:14 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Old Apr 14, 2005 | 03:15 PM
pau1rs's Avatar
pau1rs
got an efi manifold mike!!!! or i would!!!
Old Apr 14, 2005 | 03:18 PM
K3V HA's Avatar
K3V HA
Do these work on ST cossies? How much?
Old Apr 14, 2005 | 03:40 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
yeah woul;d be handy for me n all,
all i was told was that it shud remove the plastic then jam it between the hosing near the throttle body
Old Apr 14, 2005 | 03:52 PM
Mike Rainbird
Caraholic
For EFI cars, it is a bit more of a pain, but I would personally recommend drilling and tapping the inlet plenum 1/8th BSP as close to the engine ACT sensor as possible and screwing it in properly. You can then either blank off the T piece or fit a boost gauge vacuum pipe (my preferred choice).
Old Apr 14, 2005 | 03:54 PM
Westy's Avatar
Westy
Mike
dont even ask why but basically Ive broken my ACT gauge off of you I pulled and snapped some wires on the back of it Like I say, my fault
any chance of a repair, or best just buy a new one?
Old Apr 14, 2005 | 03:56 PM
Mike Rainbird
Caraholic
Westy,
Obviously I couldn't say until it was inspected, but it is likely to be repairable, unless you shorted out the screen. You can either return by post or given to me in person on Sunday.
Old Apr 14, 2005 | 04:01 PM
Thats what i did
Old Apr 14, 2005 | 04:04 PM
Westy's Avatar
Westy
cheers Mike..
dont think i shorted it out as i literally just cut a few wires I think
I will leave it on your spoiler sunday, to save me some embarassment
Old Apr 14, 2005 | 04:06 PM
Westy's Avatar
Westy
dont you mean.. give it to me ? I've heard the rumours
Old Apr 14, 2005 | 04:08 PM
EssexBoyRacer's Avatar
EssexBoyRacer
Paul, On mine I removed the temp sender from that plastic elbow thing (as it wasnt allowing any air through the vacume pipe) and I used a vacume T peice and heat shrunk the probe into the T. worked a treat
Old Apr 14, 2005 | 04:46 PM
pau1rs's Avatar
pau1rs
cheers steve!!!
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
