Fiesta to Puma Conversion won't Start
Old Mar 5, 2020 | 05:11 PM
GM6789's Avatar
GM6789
Default Fiesta to Puma Conversion won't Start
Hi all,
Converting my fiesta and have nearly finished, im at the point now where the engine will turn over on the starter but it doesnt kick in to run on its own. Ive been doing all this souly off of a heynes manual (and with the determination to make the car quicker) to perform an engine change and have no outside knowlage on this so don't know where to look to solve it.
First i checked the fuel-in line and its still dry, so i checked the fuel pump on the tank and its still connected to the two pipes and electrical plug, with no leaks. is there a certain process to mannually suck through the fuel mannually to the engine because there may be air in the system as i've had to open it to change it? Like a technique to starting a dry engine?
Not sure what to do next so anything is welcome.
Old Mar 5, 2020 | 05:29 PM
st220kyle's Avatar
st220kyle
I did the same conversion last year so know a bit about a puma'd fiesta.
Have you got the correct immobiliser chip in the key fob which should have come with the puma ECU?
Can you hear the pump prime when you switch the ignition to position 2?
Old Mar 5, 2020 | 07:28 PM
GM6789's Avatar
GM6789
Yeah i swapped out the key barrel, immobiliser and ecu from the puma into the fiesta
I can hear a whir noise but im not 100% sure what that is
maybe i can check that i havent mixed up the immobilisers and put back the fiesta one
Old Mar 6, 2020 | 03:43 PM
GM6789's Avatar
GM6789
I can't hear anything from the fuel pump in the rear just in the engine bay there's a noise.
​​​​​​Ive checked and it is the right immobilizer too
Is there anything else I can check?
Old Mar 6, 2020 | 06:29 PM
st220kyle's Avatar
st220kyle
Sounds like the pump is working if you can hear the whirrrr noise,
how have you done the wiring for the conversion?
I assume you have transferred over the entire puma engine loom and fusebox into the fiesta?
Old Mar 6, 2020 | 06:49 PM
GM6789's Avatar
GM6789
It was the pump making the whirring sound and from there I found out it had a fuel cut off switch, in the passenger footwell, which I needed to be reset, and now it's starts up every time
Thanks for all the help it's much appreciated
Old Apr 14, 2023 | 11:41 AM
shabbay2k's Avatar
shabbay2k
Mart
Default I have this problem too
I swapped out my T reg 1.25 with digital dash for a 1.7 Puma lump which had been fitted in a zetec S I got the engine bay loom , complete engine box manifold , ecu everything needed well I assume but it will not fire up the most I got was it fired but died straight away
now I’m guessing the puma loom was out off a later one as it had two lamba sensors but everything went in ok and the only management code I’m getting is fuel level sensor circuit but the gauge works fine I’m scratching my Head a bit
Originally Posted by GM6789
Hi all,
corkfordfan
Ford Fiesta
Sep 29, 2014 08:17 PM
swardy
Ford Fiesta
May 30, 2012 08:57 PM
e18rly
May 11, 2012 07:58 PM
matt-xr2t
Ford Puma
Jan 27, 2010 10:19 PM
