Cosworth 4x4 oil pump options
Alright lads,my engine is going to nms in a couple of months and I'm looking for a new original 4x4 oil pump if possible,I know the chances are very slim so what my next best option?
Cosworth have remade the original YBO 852 4x4 oil pump you can get them from modatek there Ł400 including vat
http://modatek.co.uk/wp-content/uplo...ce-list-V3.pdf
Steve
Steve
On all the new oil pumps when I fit the Emtron Ecu installation I always recommend fitting a oil pressure sensor to the ecu to cut at a drop in oil pressure. This has already saved one engine so just a oil pump change rather than a destroyed engine which saved a possible 15k engine.
Mark
Mark
Steve
Steve
Mark
Mark
it has stages in the drop , so a slight drop would limit boost/RPM and a great increase that reaches your cut off pressure can indeed shut the engine down.
Very clever tech! For someone that has spent shit loads on their engine would be a very essential feature. Years ago I had that nightmare of sudden oil pressure drop followed by bottom end bearing failure which is not good!!
Unfortunately not , as the wet wipe that was mapping and fitting the ECU install didn't put the safety features in place , luckily after a rebuild and set up via mark Knight and stu it was all set up properly.. lesson learnt .
