Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
ST170 Brake / ABS / Traction lights on after touched battery
Old Jan 20, 2020 | 12:46 PM
El-Fordito's Avatar
El-Fordito
Default ST170 Brake / ABS / Traction lights on after touched battery
I was replacing the ballast on my headlight on a 52 plate Focus ST170 and dropped a spanner on the negative terminal and made quite a spark for about 3 seconds.
Since then the Brake warning light, traction control warning lights, and ABS warning lights have remained on.
I checked every single fuse in the bonnet and glove box and one was blown but was for something unrelated. All others were fine.
I have heard there are many inline fuses coming of the battery, but I dont really know where. Could one of these be the problem?
Or is it likely I have blown or shorted something and need to go to an auto electrician?
Thanks in advance.
Old Jan 21, 2020 | 06:54 AM
oldford's Avatar
oldford
Why don't you start with having the fault codes read from the ABS?
And then based on the codes investigate further.
Old Jan 21, 2020 | 01:45 PM
El-Fordito's Avatar
El-Fordito
Great! thanks for your help. I looked it up and will try to buy one of those readers. Cheers!
Syeco666
Ford Focus ST
Apr 22, 2019 01:49 PM
-shorty-
Jun 8, 2011 11:37 AM
TylerCoop
Feb 2, 2010 07:34 PM
dazz25
Nov 28, 2009 02:05 PM
col93saphcos
Dec 17, 2008 07:01 AM
