Is this affecting the running of the motor?
Old Jan 18, 2020 | 05:03 PM
innerpiece's Avatar
innerpiece
Default Is this affecting the running of the motor?
Hi, the motor has a dent on one cylinder from a crushed valve
. I wonder if this would affect anything when running..?
Old Jan 19, 2020 | 01:50 PM
haz87's Avatar
haz87
Picture doesnt really give an idea of depth, but no not really. If the engine was running poorly it was more likely the bent valve that caused it in the first place!
Old Jan 19, 2020 | 02:38 PM
cossynut2's Avatar
cossynut2
10 Year Member
None of the pistons look very good to me and the one that has already been hit by a valve has got to be a potential weak spot in time. Engine rebuild would be what I would be looking at.
Old Jan 19, 2020 | 03:03 PM
james kiely's Avatar
james kiely
Bores look Scored which would be more of a concern
Old Jan 19, 2020 | 03:04 PM
scoooby slayer's Avatar
scoooby slayer
The question is what is it and what is its intended use ?
Old Jan 19, 2020 | 04:12 PM
innerpiece's Avatar
innerpiece
great, many thanks for answer! Its a ford focus, 04. It will be really fun to see if it actually will run again, i have ordered 4 valves that needed change.
Old Jan 19, 2020 | 05:00 PM
scoooby slayer
If it's just a standard car used as a cheap run around car id just run it, it could well go on for several thousand miles trouble free
Old Jan 19, 2020 | 06:05 PM
burnzy's Avatar
burnzy
burnzy
File down any sharp edges on the piston crown where the damage is, to help with hot spots.
and as said if it’s just a fixing exercise do as you are doing and see how long it lasts.
Old Jan 19, 2020 | 08:03 PM
stevieturbo's Avatar
stevieturbo
C**t
Looks like a pretty big whack....has it broken through ? How thick are the crowns ?
Old Jan 20, 2020 | 01:18 PM
Leevan's Avatar
Leevan
I would run it, as long as its not gone through, as above de ber, bit of wet n dry and lob it back in.
Old Jan 24, 2020 | 05:59 PM
innerpiece's Avatar
innerpiece
great, thanks I just got the valves, will fix it when i get some more time..
Yes, its a junk car, i bought it for nothing. If this fails it will be towed straight to the graveyard...
Old Jan 26, 2020 | 12:06 PM
innerpiece's Avatar
innerpiece
Different length
I got the valves thet are a few mm short. Can i still use them..?
Old Jan 26, 2020 | 05:10 PM
stevieturbo
C**t
If this is a bog standard application....then no. Buy the correct parts.
Old Jan 26, 2020 | 06:07 PM
scoooby slayer
I would definitely get the right length valves
Old Jan 27, 2020 | 07:46 AM
Just buy another engine. It will save all the fookin about.
Old Jan 27, 2020 | 10:24 AM
innerpiece's Avatar
innerpiece
haha, why would i do that..?
Old Jan 27, 2020 | 11:38 AM
haz87's Avatar
haz87
Because it probably would have cost you less than a set of valves
Old Jan 27, 2020 | 11:57 AM
innerpiece's Avatar
innerpiece
ah, might be true but i reckon it will cost me more than what i paid for the whole car, gonna use it for spare parts if it is not running okej, I need the trunk door for another car that is smashed in..
i will smack it toghether and see how it runs, the new valves are 95mm and the old are 110 mm so it will be fun to see how it runs..
Old Jan 27, 2020 | 01:50 PM
cossynut2's Avatar
cossynut2
10 Year Member
Agree with you, I am pretty sure the valves will be no good with a shorter length! I would not be putting them in my engine.
Old Jan 27, 2020 | 01:52 PM
cossynut2's Avatar
cossynut2
10 Year Member
innerpiece I don't think it will run with the incorrect valves.
Old Jan 27, 2020 | 01:56 PM
GVK.'s Avatar
GVK.
Don't do that. It will probably not run, if it does it will rattle.
Old Jan 27, 2020 | 04:09 PM
scoooby slayer
I'm all for saving money and not wasting anything but honestly you need to get the correct length valves, they cost no money at all tbh !!!!
Old Jan 27, 2020 | 04:21 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
I say fit the wrong valves and let us know if it works out fine
Old Jan 27, 2020 | 05:18 PM
innerpiece's Avatar
innerpiece
something is not right, all valves i can get hold of for FORD Focus Mk1 Kombi (DNW) 1.6 16V is 99mm. And the dealers say this is what should fit exactly my car. And the valves on the car are 110 mm...
Old Jan 27, 2020 | 05:25 PM
stevieturbo
C**t
Are you ordering for a car, or your actual engine ? Is it the correct/original engine in the car ?
More details on how you have come to this point. ie was this engine ever actually in your car and working ?
Old Jan 29, 2020 | 07:08 AM
innerpiece's Avatar
innerpiece
it is original. I bought it as the owner thought it was a blown head gasket, it was overheating. Drove it home and had great problems to loosen the cam shaft belt bolt. A neighbour helped me to loosen the bolt as he has some strong tools. retightened it and thought it was just do drive back home, didn know about ford having come up with something called floating cam belt bolts. being such a bolt, the timing belt went wrong and smashed the valves, hence the current situation.
Theese new bolts is told to be a perfect match to the engine
https://www.bildelaronline24.se/et-engineteam/8288392
https://www.bildelaronline24.se/freccia/2482156
but they arent, they are 2mm too short compared.
The valves is original, but something is not adding up. I am gonna have too look for another solution, i believe it will be possible...
Old Jan 29, 2020 | 05:02 PM
stevieturbo
C**t
buy another known good engine. There must be plenty of them out there.
carbon1993
Sep 12, 2016 10:47 AM
COLEYST200
Sep 5, 2008 08:37 PM
Brycey
May 9, 2008 12:10 PM
avengerpenguin
Sep 17, 2005 08:50 AM
Switch
22
Sep 9, 2004 09:08 PM
