R33 gtr skyline. 955bhp sequential box.
https://youtu.be/xJumiCRuGWg
Guys check this out. I need a sequential box in my life and the way it takes off. Unreal
Absolutely awesome, it's still got the manual touch for man and machine unlike a dct which is disconnected a bit from the driving experience I find
If I hadn't bought my jm1600r this is exactly the sort of car I'd of had, looks great fun, and if that is making 955 hp at 1.8 bar on an efr 9180 then that is one seriously efficient motor aswell
As long as they have ignition cut put in for shift then can flat shift just like a dct, I want one so bad lol
I cant fathom what thats like at 900+bhp, I bet its like being kicked in the stomach at every change
ah ok, I have flat shift on my B5 S4, it was savage at 350bhp and now Im running 450bhp I just burn the clutch, the s4 box isnt sequential but it does ignition cut, it feels so mechanically unsympathetic
Is it a dog box ? I can't imagine smashing a h pattern synchro box through on flatshift
but it maintains boost keeping the butterfly open, and the by-product is flames flying out the exhaust.there is pictures of gearboxes that have been stripped and its makes some really bad wear patterns on the gears and is generally not great on the boxes regarding bearings and shafts, especially on stage 3 cars running around the 450bhp mark.
i now do a Lift-No Lift Shift
so basically everything for flat shift but once Ive shown off with flames coming out the exhaust i let off the accelerator saving my gearbox and my wallet
the rolling launch I think is fairly new on these ECUs I know the Nissan and Jap boys have been playing with it for a while.
https://youtu.be/LpY4VOWd-mI
Mark
is there any real use apart from watch this factor?i can imagine with 4wd you get a fair old clump of grip too
Mark
Did look very fun... but for a street car, not for me.
Obviously great for the drag strip but doesn’t it look like you lose some of the appeal of accelerating a turbocharged car? I know some are thinking WTF man but what I mean is I’ve seen big power skyline vids and that one didn’t have the drama of the acceleration (ie having to spool the turbo again) between gears.
I guess you could use the clutch and take it easier but aren’t these boxes designed to be shifted hard and fast?
It looks almost like it makes it one relentless (aside form the BANG) ride, no doubt still barmy but I like lag & spool and on the street it’s looking to me like that gbox is egging you on to do a top speed run every time you accelerate.
I’d have that gearbox up in court with me being cross examined by the prosecution! It was HIM!
Obviously great for the drag strip but doesnt it look like you lose some of the appeal of accelerating a turbocharged car? I know some are thinking WTF man but what I mean is Ive seen big power skyline vids and that one didnt have the drama of the acceleration (ie having to spool the turbo again) between gears.
I guess you could use the clutch and take it easier but arent these boxes designed to be shifted hard and fast?
It looks almost like it makes it one relentless (aside form the BANG) ride, no doubt still barmy but I like lag & spool and on the street its looking to me like that gbox is egging you on to do a top speed run every time you accelerate.
Id have that gearbox up in court with me being cross examined by the prosecution! It was HIM!
I'm yet to drive one but it looks like a win win to me, the instant shift flat shifting of a dct gearbox with the feel of a manual shift
I certainly wouldn't want lag for the sake of lag lol
My Humber is a 4 speed auto with Hurst shifter and manual valve body, I drive it in the same way throttle flat to the floor and just pull back to go up the gears one at at time constant acceleration.
No turbo speed sensor on it and the turbo would be in over speed at that level and will fail and a largest walbro in tank wont do that power. This is a quick observation without seeing all the real details. Fast car though as it should be with a large amount of power.
Mark
Mark
Could the turbo physically flow enough air for 955 hp at just 1.8 bar, I know the boost pressure is only the resistance of flow but even so seems a very low pressure to be running the turbo at flat out flow
Yeah, I know Im a weirdo Ive never got the problem with turbo lag its like foreplay. I wasnt trying to be a downer on it just looked more suitable for the drag strip and a serious lead on to a jail time driving that on the road. You can see every time they go for it, theyre in the zone and go through the gearbox banging away like its how it has to be done. It doesnt look like it lends itself to a chilled squirt on a Sunday.
I like to feel like Im going faster than I am on the road rather than actually going silly fast. Talking to my mate about it not long ago, my old 320bhp classic STI feels nippy enough when it hits boost but his DSG Audi S3 would walk from me. Being in his car though it just feels so linear and you can hardly tell when it changes gear, its more akin to an electric car and it seems what modern car gearboxes want to achieve as its so quick it just stays in the turbos efficiency zone.
Id probably go as far to say as Im sure Id enjoy the Aventador gearbox over the Hurracan. Again, sure the majority would think Im stupid.
At 955hp on pump its all about airflow from turbo =shaft speed so turbo imo would deep in to over speed and the exhaust wheel will fall off as turbo running well beyond it safe limits.
Anyone that runs a 9180 past 800hp has to run a speed sensor imo or they are just playing with fire.
Mark
Being polite its rated to 940hp I would be surprised if it could do.
Mark
Mark
It baffles me a bit they say 3.0, big valves and big cams which would surely hurt response for more flow at high rpm, but then say it's making boost at 2400 rpm with virtually no lag !
The 0-60 in 3 seconds proves nothing I've done 3.2 with a stick shift h and 550 hp over 1.5 ton car
Id like to see some stats for it as 100-200 kph should be easily below 4 seconds for 950 hp in that car with sequential flat shift around 1.5 ton
I love it looks a fast car and great fun, but 950 hp, boost at 2400 rpm all from a 3 litre on pump fuel I didn't know it was possible to have all three of those things in a sentence, I would say only 2 of those things are physically possible .........
I love a sequential box though, whatever it's in!
Even super fast spooling have obvious lag on the Cossie and when the boost comes in there is more of it, I think the character is the same and a good mapper can replicate whatever you like.
You have to remember....it's an internet video. So it's likely full of shit made up for the camera. A bit like old articles in a lot of magazines....they make stuff up so it reads better for the....well..sometimes I wonder who lol
Thing is one mans better is another mans worse I guess. I prefer old school which is why Im still driving round in a 20 year old STI & an 18 year old WRX when my mate has an S3s with DSG box. But when I go out with him hell be in his van all the time, when Ive got an opportunity to use my car I will as I still want to drive them after 7 & 6 years owning both.
When I was buying in the motor trade I drove hundreds of cars and would keep some a few days. Id always get in a newish interesting car and think I like this that would last between 5 minutes and a couple of days.
If youre striving for lightning fast gear changes and response you May as well just get something modern but it bores the tits off me to be honest. I do agree with the chap about a cossie, why aim to make one drive like a modern car.
Theres zero character in any of these new modern performance cars, everything looks the same under the bonnet compared to the rest of the model range and good doesnt equal driving pleasure to me.
If I wanted a car that was super responsive, I'd buy one that was like that I think. In my view (and I accept that we're all different), making a car faster doesn't necessarily make it better. Making it better to drive objectively doesn't make it better subjectively. My old Golf R was objectively better in every way than a Cossie, but I know which I would rather own. The boosty, laggy, 'kick in the back' from a Cossie on a period turbo is part of the appeal. Take that away and it's not a Cossie anymore to me. It's like my current daily smoker, a Clio RS 197. Loads of people put the engines from the Megane 225 in them. It makes them a lot faster and even more economical in some circumstances so, objectively, it probably makes it a better car. I have no interest in it though. Part of the appeal of the car is the revvy, normally aspirated engine. Fit a turbo lump and the character of the car is gone.
I'm sure plenty don't share my view though!
