What do these connect to?
Old Jan 9, 2020 | 05:17 PM
GM6789's Avatar
GM6789
Default What do these connect to?
Hi everyone,
I'm currently working on putting a Puma engine into my Fiesta and have almost finished bar these few wires and two holes.
Any help would be much appreciated, thanks in advanced.
Old Jan 9, 2020 | 05:39 PM
studabear's Avatar
studabear
2nd pic looks like coil pack
Old Jan 9, 2020 | 05:42 PM
st220kyle's Avatar
st220kyle
Originally Posted by GM6789
Hi everyone,
1st pic, can't really tell from that picture
2nd, either coil pack or maf, depending on colour cables?
3rd/ 4th need better picks
5th, the big one plugs into the abs module and the small one looks like it plugs into an abs sensor (behind wheel arch)
6th I think it plugs into a sensor on a bit of pipework for the power steering on the drivers side near the bottom of the radiator.
Old Jan 9, 2020 | 06:56 PM
GM6789's Avatar
GM6789
Thanks for the help so far guys. I'll try to get better pics tomorrow, the fiesta didn't come with any abs so doesnt have a module. Ive got the abs sensor already tied up on both sides because i havent fitted the puma hubs that have the abs sensor, so the smaller black one must be somthing else :/
The power steering pipe ive already connected so the round red one must be somthing else too.
I need to check tomorrow but i think it might be right to be the coil pack connection.
the two holes are really hard to get to theyre just below the altinator, i think maybe connected to the water pump and may be for temp sensors but cant understand why thy would have been taken out.
Old Jan 9, 2020 | 07:08 PM
st220kyle's Avatar
st220kyle
Ok then, the plug I originally said was for an abs sensor? What colour are the wires? If they are blue/purple and orange/purple they plug into a connection that comes through the scuttle panel and goes off under the hcv.
The bigger one is definitely for the abs module though.
Old Jan 9, 2020 | 08:18 PM
RichieST's Avatar
RichieST
The 2 holes with the green o rings, is that not for air conditioning pipes to connect to?
Old Jan 10, 2020 | 09:46 AM
GM6789's Avatar
GM6789
Thanks for the help
Done a bit more research with this in mind and yes it's the AC pump, but the fiesta didn't have, the condenser is it?, So I haven't got anything to connect the pump to.
If I bought the pipes for it and just made them into a pipe running back into itself would that work? Or is there another way of plugging them if I need to?
Old Jan 10, 2020 | 12:05 PM
st220kyle's Avatar
st220kyle
No point really if you don't have AC in the fiesta, I would remove the condenser and replace the aux belt with a smaller non AC belt.
pacwest
12
Nov 28, 2015 11:32 PM
craigfocus
Apr 5, 2012 04:46 PM
Char1ie
Dec 24, 2008 08:57 AM
motherhupit
11
Aug 14, 2008 09:15 PM
