Diesel problems
Have a 1992 1.8 Turbo Diesel Sierra, it has good heater plugs, new battery and diesel filter. I’ve cleaned the tank and ran new diesel lines from the tank to the pump. I’ve swapped the filter head for a known good one.
Its hard started and when it does start it idles high and won’t rev at all. Anything I can do or try to get it back going right again? Also the Rev counter has stopped working. Thanks
i think there become noisey when dead.. the only other thing it could be is the diesel pump as them engines are mint apart from timing belt snapping when un changed there run for mega miles i used to do loads back in day services etc
I have another turbo diesel Sierra engine here that’s running I will take the pump off that. The pump is slightly different it doesn’t have the red switch with the 3 wires going to it on the top of the pump, it’s coming off an engine with no egr Valve on it If that makes a difference, I’ll put up pictures to show difference in pumps, they aren’t my ones just want to show the difference
Rich_bloor
Feb 15, 2008 09:45 PM
