ST225 alternator
Old Jan 4, 2020 | 06:46 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default ST225 alternator
My alternator is fooked anyone changed one are they easy to get off do you have to take the inlet plenum off. Deciding weather to do it a at home on my drive. Can it all be done from the top also what do you need to de tension the belt. ( I don’t work on cars much so never done one I have a good selection of tools at home but limited)
Old Jan 5, 2020 | 08:11 AM
Found a video here.
https://www.google.co.uk/url?sa=t&so...IAzx7satutxl9f
Old Jan 5, 2020 | 08:13 AM
Looks like a right chew on.
Old Jan 5, 2020 | 08:24 AM
ajamesc's Avatar
ajamesc
Yeah I will probably have to take it too work. I’ll have to charge the battery and see if it will drive there
Old Jan 7, 2020 | 07:41 PM
Good luck. We arnt allowed to use ramps at my place of work now. Insurance lol.
Old Jan 7, 2020 | 07:52 PM
ajamesc's Avatar
ajamesc
There’s pretty much no rules at my work there a joke lol. I’m on call this week so can’t do anything with it I got the alternator for 230 from ford parts direct. I’ll charge my battery on Monday and hope it will drive to work like it is as I only live 2 minutes away.
Old Jan 7, 2020 | 09:54 PM
studabear's Avatar
studabear
I did my wife's just before Xmas.
If It still has the standard airbox then drop the radiator cradle off it's bolts let the rad pack dangle on the hoses. Unbolt the ecu and it's wiring from the airbox, separate the intake pipe and the pipe that feeds the turbo. Manhandle the airbox out the way. This is the worst bit.
Unplug wiring plug on the throttle body then unbolt the upper plenum. Think that's 6 bolts and maybe a vac pipe. 1/4" socket set will be a big help here.
After that it's pretty straight forward.
I would renew the drive belts while you are at it.
I also wouldn't t really want to do one in the floor.
Old Jan 8, 2020 | 04:16 AM
Defo sounds like fun lol.
Old Jan 8, 2020 | 07:13 PM
GVK.'s Avatar
GVK.
If it's never been off before just taking the airbox out is as Glenn would say "A right chew on"
Not the best things to work on.
Old Jan 8, 2020 | 07:44 PM
ajamesc's Avatar
ajamesc
I’ll know on Monday or Tuesday lol I’ll manage it just how long it takes lol. While it’s in the air I’ll do the front shocks strut top bearings and drop links as well. And as I have to take the air box off I’ve ordered a new oil module diaphragm as well
moesin2005
Mar 15, 2017 09:01 PM
Mitcht88
Nov 5, 2013 07:17 PM
craig todd
Apr 15, 2008 10:36 AM
NEWTON
Jul 22, 2006 06:20 PM
tonyturbo
May 2, 2005 05:04 PM
